Pentax Optio S6 Digital Camera Logo
Posted on Mar 05, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When I insert a Fujifilm 2Gb SD memory card in to my Pentax optio S6, the screen will switch on but nothing else works. Any ideas ?
  • mpbriggs Mar 05, 2011
    No but I've read that it will not work with 2GB cards
W.L.
Level 3:
  • Master 2,511 Answers
  • Posted on Mar 05, 2011
W.L.
Master
Level 3:
Answers
2511
Questions
Helped
524314
Points
8345
Does it work with other cards?
Hi - I have a Pentax S6 with a 1 GM SIM card. I just bought a 4 GB SIM card and am getting a memory card error message. The camera doesn't work with the 4 GB SIM card. What's wrong? What should...
The S6 works with SD cards. Your 4GB card is actually an SDHC card and will not work with your camera. You need to use SD cards, 2GB and smaller.
I just bought a new verbatium 8 gb SDHC memory card for my Pentax S6 camera and it does not work powers on but can not get menu funtions to work. my old card is a SD 1GB works fine are the new SDHC cards...
No. The S6 works with SD cards, not with SDHC cards. While SDHC cards will fit into the slot, they are electronically incompatible and will not work with devices not designed to use them. You need to use SD cards, 2GB and smaller.
2helpful
I have purchased a 4GB SD-HC memory caard for my pentax optio s6. when istalled the card, the screen was turned on ok, but could not perform any function. Few minutes later a "memory card error"...
The Optio S6 works with SD cards, not SDHC cards. While SDHC cards will fit into the slot, they are electronically incompatible. You need to use SD cards, 2GB and smaller.
Jan 13, 2011 • Cameras
3helpful
Memory card Sandisk 4GB gives error memory card
The S50 uses SD cards. Your 4GB card is actually an SDHC card, and will not work in the S50. You will have to confine your choices to cards 2GB and smaller.
I have a pentax Optio E10 camera and put a 4gb sdhc memory card in but it doesnt respond when I switch it on - does this mean it is not compatible or is there a way of sorting the problem
The manual specifies SD cards up to 1GB. Cards bigger than 2GB are actually SDHC (SD High Capacity) cards and will not work in SD devices. 2GB cards may work; try at your risk.
1helpful
Memory card
  • Supported Flash Memory: SD Memory Card Integrated Memory: 23 MB
  • yes you can used the memory card with this.
2helpful
Camera won't read new SD card
The sd card is to big go for a 2gb ted10
Sdhc memorty card in a pentax optio e10 camera
The E10 works with SD cards. While SDHC cards will fit into the slot, they are electronically incompatible and will not work. You need to use SD cards 2GB and smaller.
Top Pentax Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Rob Hill
Rob Hill
Are you a Pentax Camera Expert? Answer questions, earn points and help others
