My TV,cable, DVD are all connected with my Rotel receiver. The sound doesn't work anymore with cable or DVDs. It comes on sometimes and then goes away. Sometimes if I change the channel the sound will come back on but then goes away again. And sometimes the speakers start to make a strange, static/screeching noise and then the sound goes out again. Radio, DVDs, TV don't work. The only that seems to work fine is Internet Radio through our Squeezebox.
Can you help?
Thanks,
Jodi
Rotel RSX 1067 is a good and powerful unit. But as stated over time heat and vibration will cause issues in these big A/V receivers.
I have repaired many, and for the most part it is solder connections on the power supply board feed-throughs and such. Loss of voltages to the digital board, or blown outputs caused by improper speaker wiring and or loads. All of the above is repairable but only with a very knowledgeable and person used to repairing these units. It is not for the DIY weekend warrior.
Normally when sound disappear, this was cause by some grounded wire inside or some connection is lessen. That is why when changing the channel sound come up sudden change in voltage and then disappear when the voltage drop down to normal state.
so loss connection in some areas where the cable and dvd where connected. try to check it. if symptom persist, another is grounded connection. you have to put and connect wire from any metal of your stuff and then directly connect to the ground.
To troubleshoot of what stuff got an error you have to disconnect DVD player and the rotel receiver to isolate which one got an error.
melnavz
The problems you are describing are typical of a DSP board or digital board problem (same board, referred to as DSP or digital board). Sometimes these type of failures can be repaired by reflowing the solder on some of the IC's on that board. It would require excellent soldering skills. I repair these type of units on a daily basis and have been for the last 18 years, so I know what I am talking about. Your problem will be a very difficult one to isolate, even by a very good technician. The digital boards are the hardest to troubleshoot. With an O-scope you can see the data when troubleshooting, but most times you can not tell if the data is good or if it is corrupt. This makes isolating the problem very hard unless the data is just missing or riding on an imporper voltage level.
I am sorry to tell you, it will not be an easy fix for you, nor will it be for a repair center. If a repair center can get a new board for you, it wold be the surest fix, but the boards for audio equipment are very rare.
Your best bet is to take it to a repair center and hope that they can restore proper operation by either reflowing the solder on what ever IC they may think is causing the problem or be able to get the part and replace it. There is just no way to know for sure what part is causing the problem without troubleshooting the unit with the proper test equipment.
Your speakers are not causing this problem, and none of the other devices connected to the unit are causing it either.
I work at an authorized service center for brands like Pioneer, Kenwood, Denon, Marantz, Onkyo, NAD, Panasonic, Samsung, and the list goes on, but not for Rotel. It is not one of the more popular brands for surround sound receivers.
I wish I could tell you of something that would fix your unit, but I don't think this will not be one of those rare occasions when resetting the unit or anything like that will help.
I will help you further if you would like, but I am not sure there is really anything that anybody here can do to get your Rotel working properly again considering the symptoms you described.
Dave
Loose connection or cold solder and cleaning problem this is the main caused of no sound..Cold solder issues - each
component is soldered into small
holes on the printed circuit board which in turn connects said
component to the
other components. Due to time, heat, use, some solder joints would be
cracked
or loose. It is possible that the cold solder is still minimally
connected
(hanging by a thread). When the receiver turns on heat would be
generated which would
be sufficient to further loosen up the solder joint to the point it no
longer
provides electrical contact. Jarring the unit creates movement inside
enough to
re establish the contact, sometime good enough sometimes not enough.
Again, since the unit still operates (sometimes) then it is highly
probable that there are no defective components. As you have surmised, it is
possibly a loose connection, solder joints are "connections"
except that molten soldering lead is used to attach/connect the component to
the board, "loose connection" in this sense is equal to "cold
solder".
Again on the assumption of no defective parts, then seeking a more
experienced
buddy for the soldering might be to your advantage. This is of course
in
addition to the possible electrical hazards when repairing....
Good luck:
Regards,
VOTIT
Hi Jodi
you can use alternate audio input/output, due to coupler issue sound might not work a particular channel.
please refer the user's manual and check alternate configurations has been indicated. click here for the user's manual
please post if you need further assistance
Good Luck
The rotal reciver is on the way out to the bin ,,,i chucked mine out and got a new one and was all good again i had same problems thats all i have to say and i dont think there is a fix to that
that was the least technical advice i can imagine receiving. is this site for real? i would like an explanation to the situation please. the receiver is only 2 years old.
I would like to try the solution posted by AvioriX but I don't know how to do this.
Also, what would have made the system stop working correctly? And do you think it's definitely the receiver and not the speakers?
Can you help?
Thanks,
Jodi
Solution #1posted on Jul 29, 2008
AvioriX
Rank: Guru
Rating: 91%, 304 votes
Hi Jodi
Good Luck
