Ovens Logo
Posted on Feb 26, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do you get the small glass globe off tht is covering the light bulb in my Maytag oven. The light bulb burnt out and cannot remove the covering to get to lightbulb. Thank You
Randy Martinez
Level 1:
  • Contributor 1 Answer
  • Posted on Nov 12, 2022
Randy Martinez
Contributor
Level 1:
Answers
Questions
0
Helped
498
Points
Use a oil filter wrench , worked great.
Mark Nielson
Level 1:
  • Contributor 15 Answers
  • Posted on Dec 28, 2017
Mark Nielson
Contributor
Level 1:
Answers
15
Questions
Helped
82172
Points
51
Put wide rubber bands around the cover to get a better grip.
Anonymous
Level 2:
Champion:
  • Expert 235 Answers
  • Posted on Feb 27, 2011
Anonymous
Expert
Level 2:
Champion:
Answers
235
Questions
Helped
75853
Points
387
Most of these glass knobs are thick glass and strong. Trying using a pair of multigrips to turn it, just be gentle.
How do you remove glass cover inside the oven to replace the Globe?
normally there is a very course thread that is gummed up by burnt fat and grease
sometimes spraying oven cleaner around the glass and into the thread will loosen it up but even then you will require considerable force to move the glass in the socket
the replacement bulb has to be a special pyrex bulb glass as normal bulbs will not last past the first bake
Aug 08, 2018 • Ovens
I an not undo stuck light cover for a Simpson evolution 904 convection oven to replace the globe
generally the grease and fats from cooking burn in the thread of the glass and lock it up
try using oven cleaner at the base and see it that releases the burnt grease
remember to use only Oven bulbs as regular bulbs will not stand the heat in an oven
Jul 27, 2018 • Ovens
Cannot remove the glass cover to replace the light bulb.
it is a very course thread that gets bound up with burnt fats
use grips or soak the area with oven cleaner to loosed the carbon up
only use special oven bulbs as normal glass will break from the heat of the oven
May 31, 2018 • Ovens
Any suggestions on how to remove covers on lights in Ilve oven so I can replace globes? Tried warming oven as suggested but they wont budge. Is the only solution to get an Ilve technician?
when you go to the service agent to get the correct bulbs ( (need to be pyrex glass ones as normal bulbs will not stand the oven heat) ,ask them how to remove
the fat from cooking gets in the glass threads and then goes to carbon , making it very hard to turn the covers
maybe a oven cleaner sprayed around the glass may help release the threads
Jan 14, 2018 • Ovens
How to access oven light
There should be a glass globe that covers bulb. It either screws out or is held in with a stiff hinged wire. Remove globe and then bulb. Sometimes bulb will break trying to get it out. Be sure to unplug unit when trying to get a broken bulb out.
Nov 10, 2017 • Ovens
How do I change the bulb inside the cooker of the B5741 cooker
Oven Lighting
Warning: There is a danger of electric shock! Prior to changing
the oven light bulb:
  • Switch off the oven!
  • Disconnect from the electricity supply.
Place a cloth on the oven floor to protect the oven light and glass cover.
Replacing the oven light bulb/cleaning the glass cover
  1. Remove the glass cover by turning it anticlockwise and then clean it.
  2. If necessary:
Replace bulb with a 40 watt, 230 V, 300 °C heat-resistant
oven light bulb.
3. Refit the glass cover.
Dado
Apr 15, 2015 • AEG Ovens
HOW TO REPLACE THE LIGHT BULB IN MY OVEN
Oven Lighting
Warning: Risk of electric shock! Prior to changing the oven light bulb:
- Switch off the oven!
- Disconnect from the electricity supply.
Changing the oven light bulb/cleaning the glass cover
1.Remove the glass cover by turning it anti-clockwise and then clean it.
2.If necessary: replace with 25 watt, 230 V, 300 °C heat-resistant oven lighting.
3.Refit the glass cover.
24472822-skr3uzd4ii43xzwyhmpsswym-3-0.jpg Dado
Replacing oven light
In general you slide out the front glass cover on the light, which generally just sits in metal slots or clips. Then remove the globe, which commonly is an ES type so you screw it out anti-clockwise.
There are 2-3 sizes of oven globe so take the old one along to the hardware store for a match. Don't buy a standard globe, it will fail, oven globes are tougher.
Nov 27, 2013 • Ovens
How do you change the oven light? Cannot undo light cover.
Most oven lights have a wire over the glass globe, pop it sideways & remove the globe.
Nov 30, 2009 • Smeg Ovens
6helpful
Remove light globe from simpson harmony nova oven
The glass cover is a screw in. You will need to remove this by turning anti-clockwise to get to the globe.
Jun 01, 2008 • Ovens
Top Maytag Ovens Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Paul Carew
Are you a Maytag Oven Expert? Answer questions, earn points and help others
