SOURCE: I have a sirius stiletto
Your audio out pins on the dock, or on the top of the radio are loose. The BGA connections on the chips inside may also be loose, but that is less likely depending on the force of the collision.
SOURCE: Hi there I have a "SAT FAULT" displaying on my pre
SAT FAULT is displayed when the radio can't pick up the sattelite because either the antenna or the tuner are faulty.
There is nothing you can do about that, the radio will have to be removed from the dash and tested. If the radio is fine then the antenna, located on the roof, will have to be replaced; this implies the removal of the roof trim , a complicated and time consuming job that needs 2 persons to be done correctly. Your SUV should still be in the warranty period so the repair should be free at a dealer.
