I have a monitor soyo model mt-ni-dylm1986. At first the monitor got black without any reason but i only move the power cord and it function again. Now when i plug the cord the blue power on ligth blinks, the screen also blinks and sound something.
check first any broken ribbon wire going to lcd panel or broken screen display. if those are good, the cause of white screen would be bad lcd controller board.
Your windows 7 screen resolution is set too high and your display doesn't support it. There are 3 possible solutions to this problem: 1. Press F8 during startup and choose "Enable row-resolution video" 2. Press F8 during startup and choose "Safe mode" and change screen resolution there, then reboot. 3. You can always use another display (if you have one) to set screen resolution to lower value.
Thank you for answering those questions. That usually indicates it has a bad power inverter. From what i can tell, that monitor is a few years old. You can attempt to find an inverter online to replace it yourself (usually about $50 if you can find one) since its no longer covered under warranty, or put that money into getting a new monitor.
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums Post back what you see inside so we can guide you further.
i have encountered this same issue with a monitor like yours its very common especially for lcd monitors there is a bad diode on your monitor board and you will not be able to fix this yourself you can buy another or use just a regular crt monitor or your best bet is to have it repaired im sorry and i hope this helps
