Dishwashers Logo
Anonymous Posted on Feb 23, 2011
Asko D1976 dishwasher, water flow does not stop
Ned Halaweh
Level 2:
  • Expert 240 Answers
  • Posted on Feb 23, 2011
Ned Halaweh
Expert
Level 2:
Answers
240
Questions
0
Helped
49843
Points
502
Hi, you either have a broken water inlet valve, or your float is stuck in the down position or it may be broken. Best of luck.
  • Anonymous Feb 24, 2011
    Hi Ned, My earlier info was a bit sketchy.
    had the F2 fault and did the usual sump clean/dry, but this time iI have another problem
    The water starts flowing when I put the power on and does not stop, checked the float, when activated this starts the drain pump and shows F2 fault, checked the level switch OK.
    Water inflow only stops when the power switch is off.
    Have used the machine by controlling the water manually cycle is OK
    Jude
D1976 machine won't do anything but pump out.
The flood switch must have tripped. This is likely to happen if there is a water leakage.
If you can pull the dishwasher out (after turning off the power and water connections) and tilt it on one side. Wait a little (to let the switch dry up) and then turn it on.
Hope this helps.
Hi I had f2 flash up on the control panel so we drained it and turned it back on it now shows 5 on the control panel and wont do anything else it is a ASKO D1976
Hi
Error F2 in asko dishwashers indicate high water level. This may happen due to plugged drain pump or due to faulty water inlet valve. To resolve the issue remove the back plate and check the drain pump. Disconnect the hoses from the drain pump and clear the lint from the hose and the pump area. Lot of water would be there when you'll remove the hose from the pump, be ready to collect it. Let it dry and now the dishwasher will work perfectly now. Hope it helps...
Daniel
2helpful
3answers
My Asko D1976 dishwasher is not cleaning dishes properly. There is a lot of clumped detergent left in the dispenser after wash cycles are complete, and many of the dishes have dried-on food left on them. ...
First of all, don't pre-rinse the dishes. Check the water temperature, it should be between 120 and 140 degrees. Be sure you are not partially blocking the dispenser door so that it isn't opening.
1helpful
2answers
My Asko dishwasher is not draining. Code F2
drain plugged, hose kinked or discharge pump bad
My Asko D1976 dishwasher is not cleaning well, and
I would check you drain it must be clear and it must also raise above the bottom of the sink to keep water from the sink going back into the dishwasher..
Hope it helps if Not let me know more about you problem..I can help
2answers
F2 error message flashes, cannot reset.
Try to find out from where water leaking from (pump or inlet valve). The leaking one, should be replaced. Good luck !
Top Dishwashers Experts
Mike Cairns
Mike Cairns
john h
