Emerson Smartset Clock Radio Logo
Posted on Jul 27, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Radio plays for no reason
Radio plays in the middle of night for a second or two then goes off. happens about every hour or two sometimes. gordon
Anonymous
Level 3:
President:
  • Master 814 Answers
  • Posted on Jun 14, 2009
Anonymous
Master
Level 3:
President:
Answers
814
Questions
0
Helped
447830
Points
1474
Sorry it took so long to reply to your problem.You must try to reset the Clock/Radio's microprocessor. To do this you must disconnect the Clock/Radio from the A/C power source and remove the internal battery. Let the Clock/Radio set without any power source for about 3 hours. This should completely drain all the power from the microprocessor. After this is done, reinsert the internal battery and plug the Clock/Radio into the A/C power source. The Clock/Radio's functions should return to normal. If they do not return to normal. Unplug the Clock/Radio from the A/C power source and remove the internal battery. Replace the internal Battery (CR2430). Let the Clock/Radio again drain all the power from the microprocessor. Insert the new battery and Plug the Clock/Radio into the A/C power source. The Clock/Radio's functions should return to normal.If you should still be having problem with the functions of the Clock/Radio, you will need to call Emerson Customer Support. The telephone number for Emerson Customer Support is 1-800-909-1240. Call them between the hours of 8am-4:30pm CT. Give them the make and model number of the Clock/Radio and ask them for assistance with your problem. I hope this information help you with your problem. Thank you for using FixYa and have a nice day!Sorry it took so long to reply to your problem.You must try to reset the Clock/Radio's microprocessor. To do this you must disconnect the Clock/Radio from the A/C power source and remove the internal battery. Let the Clock/Radio set without any power source for about 3 hours. This should completely drain all the power from the microprocessor. After this is done, reinsert the internal battery and plug the Clock/Radio into the A/C power source. The Clock/Radio's functions should return to normal. If they do not return to normal. Unplug the Clock/Radio from the A/C power source and remove the internal battery. Replace the internal Battery (CR2430). Let the Clock/Radio again drain all the power from the microprocessor. Insert the new battery and Plug the Clock/Radio into the A/C power source. The Clock/Radio's functions should return to normal.If you should still be having problem with the functions of the Clock/Radio, you will need to call Emerson Customer Support. The telephone number for Emerson Customer Support is 1-800-909-1240. Call them between the hours of 8am-4:30pm CT. Give them the make and model number of the Clock/Radio and ask them for assistance with your problem. I hope this information help you with your problem. Thank you for using FixYa and have a nice day!
1helpful
36" KitchenAid microwave has been beeping for no reason. It's like someone is going to use it and it changes the display. Happened in the middle of the night. I cleared it, but it keeps happening
Erratic behavior sometimes occurs when microwaves are not plugged into grounded outlets. Make sure it is actually grounded. If so, you might have a defective control panel.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Alarm goes off middle of night for no reason. viper model 5704V
u seem to hav a computer/module system issue--get a data stream run that shows values so a good tech can decyfer-need factory gear not a 20dollar scanner--stay away from dealers-------1st tho try anothr remote or changn batts--or even disconnect car batt fora minute
2answers
Mr. Steam Prr erro
Hi, kindly check the connection of your temperature probe down to the main board maybe its loose.
05 Suzuki Forenzo Radio Problem
Display connection faulty, take apart and check connection from the display screen.
Radio of Durabrand Clock Radio WA-211C plays every hour on the ho
Thank you very much for your reply; I think I may have solved the problem by changing the Time settings to 24 Hour, rather than a.m. / p/m. I did this yesterday evening and the radio didn't come on every hour for a few seconds as it had been doing so I'm hoping this solves the problem, although there doesn't seem to be a logical reason why it should! I haven't yet tried setting the alarm function, so I can't be 100% certain that the problem has gone but I am hopeful.
On the basis that I had tried everything else, this seemed to be the only (last) possibility available; once again thank you very much for your reply - I don't know whether this solution is helpful to you.
Barry Sykes
RCA RP3750 - set up for No alarms at all?
1. Press "Off"
2. Press "Cancel" then press "WK1"
3. Press "Cancel" then press "WK2"
2answers
Radio turns on and off by itself
I think It might be the anntenna.
Top Emerson Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
