Frigidaire GLTF1240A Front Load Washer Logo
Posted on Feb 21, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The fabric softner tray isn't draining - Frigidaire GLTF1240A Front Load Washer
Anonymous
Level 3:
  • Frigidaire Master 43,501 Answers
  • Posted on Feb 21, 2011
Anonymous
Frigidaire Master
Level 3:
Answers
43501
Questions
0
Helped
10845336
Points
101584
Here is a tip that I wrote about what I found out about the fabric softener not dispensing into the washer...
Fridgidaire Washing Machine Fabric Softner not going into washer
heatman101
Detergent dispenser tray not draining water after cycles
I have the same problem and sometimes water stays in the detergent tray as well. I don't have a solution other than to remove the whole tray and drain in the sink after each cycle.
My washer wont drain out the fabric softner just adds water to it. cleaned the part where i put the softner thinking it was clogged but still happening.
Usually, the softener syphons out from the tray. The tray will have a tube, the tube will have a cap. Water filling the tray forces the liquid around the cap and tube. The falling water (now inside the tube) creates a vacuum-syphon effect.
Pull the tray, remove the cap, clean and try again. Provided the water's getting there, this should help.
Regards! --W/D--
1helpful
FABRIC SOFTNER TRAY STAYS FULL AND IS NOT RINSEING OUT
HiYa dh1200s
The softener tray needs to be cleaned out or the sensor for this replaced.
Yes, not enough water entering machine so not enough water to rinse out the softner
Please leave a good rating before you sign off.
Fabric softener not dispensing
Fabric softner trays often clog up, because a little soap powder in the tray by accident tends to block it. If you pull the soap tray out as far as it will go, you will see that there is a bit of the tray right at the back, probably on the left with an arrow or thumb print or indentation in it. If you press down on this it is a catch and it will allow you to remove the tray from the machine completely. Once out of the machine, the fabric softner cover will also lift out. Clean everything throroughly (Tak it outside and turn your garden hose full pressure on all the holes on the tray and then scrub it out with a toothbrush. Put the fabric softner tray mabc in and slide the soap tray back in the machine. This should have fixed it.
My neptune washer will not drain the fabric softner container
This is joyce
I have advice for you check the siphon cap to see if its twisted reposition cap.
thanks
joyce
Fabric Softner not leaving dispenser
Run some vinger through it. Fabric Softner leaves a filmy residue that can clog it up.
Fabric softner will not drain
You can get the tray with the door out? Good, soak it in hot water those inserts should pop out. Softener is next to glue and it needs encouragement sometimes.
Fabric softner tray is left full of murchy water after wash cycle has finished. Machine is brand new and only been used once. Its a Hotpoint Ultima WDD960 washer dryer.
is the machine got good water pressure cus somtimes little water gets in the fabric soften tay and it dosent flush all the softner out. hope this helps.
Tray that holds fabric softner does not drain
I have had three sepaerate service calls and one independant analysis about this problem. For the whirlpool duet washer - this is a design flaw - nothing else - please notice that when you take the detergent tray completely out (and turn it upside down) a piece of plastic falls out but even if you put it back correctly the water only flows out into the washer - either washing everything away or leaving it behind - I have been told there is no fix.
7helpful
Fabric softner
Remove the dispenser tray. Inspect the area just above the fabric softener portion of the dispenser. There should be a series of holes where water feeds into the tray during the rinse cycle. Sometimes these holes become clogged with fabric softener residue. If the holes are clogged, water will never dispense the fabric softener out and it will stay in the tray. If you take some cotton swabs and meticulously clean all the holes out, I bet your problem will go away. Let me know if this was helpful to you.
Top Frigidaire Washing Machines Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
