Brother SE-270D Computerized Sewing Machine Logo
Posted on Jul 26, 2008
Instrucitnos for Brother SE-270D Timing Problem
Need Instructions on how to set the timing on my Brother SE-270D embroidery machine, please.
Thanks!
Margie Campbell
Level 1:
  • Contributor 29 Answers
  • Posted on Aug 12, 2008
Margie Campbell
Contributor
Level 1:
Answers
29
Questions
Helped
24795
Points
76
This is not really something you can do yourself (been there, tried that!). The machine has to be almost completely disassembled to get to the timing mechanism. Trust me, it's worth the 30.00 to have it timed.
I think http://www.allbrands.com has a generic timing explaination for sewing machines (use the drop in bobbin one)...I found it easy to follow...but once I realized I had to unplug all the components for the computerized functions... I took it in to the dealer. If you contact Brother & your machine is under warranty, they will pay for the repair (they paid for my first two re-timings). Now I know you HAVE to use BOBBIN thread that is 60 WT only in the bobbin. You will continue to have problems if you don't. Also, this machine uses the class 15 bobbin, but make sure its model number SA156A, which is a hair taller than the SA156 bobbin..both are class 15, but the tiny difference is very important.
How do you change the light bulb on the Disney 270D embroidery machinr
The Brother 270D uses an LED light. Part number XC3503021. The assembly costs about $25. I do not believe this is a user installable part.
I have a Brother Se 270D sewing/embroidery machine. It makes a terrible grinding sound and won't go all the way up or down. I have removed the thread, bobbin, and bobbin case and cleaned all of...
Take it in for service, hopefully it is still under warranty, I have sneaking suspician that your motor is causing the problem. I had a machine that did that and it turned out to be the motor.
Hi,i have a disney sewing and embroidery amchine.It won't loop th it was threads together.Local repair man said it was o/ut of time.CAN YOU HELP/
If the timing is off is needs an authorized repairman to fix it with metric tools. Not a repair that can be done at home. Usually costs between $50-150 depending on your area.
2answers
Brother embroidery machine broken
make sure the bobbin thread is wound and installed correctly
remove tangled thread and clean lint out from under feed plate
clean and remove shuttle to clean out area with lint brush
inspect bobbin for burs and scratches...make sure when reinstalling shuttle and bobbin that it rotates freely
hope this helps
I need a replacement needle to embroidery. need to know the model#. I have a Brother SE-270D Easy Thread Cassette System.
The thread cassette has no bearing on what needle you use. You need a Schmetz embroidery needle with the red band size 75 for light to medium weight fabrics or a size 90 for heavier fabrics such as denim.
Brother SE-270D - need timing instructions
If your machine bunch up the tread, it has nothing to do with timing. In 90% of the cases the problem lies with the top thread. Check your tension disks for any fluff or thread. Also check that you thread the machine correctly. The best way to check the tension is to thread the machine normally with the presser foot up. when you get to the stage of the threading the needle, first lower the presser the presser foot and check the tension by pulling the thread slowly with your right hand and adjust the tension with your left hand. On zero you should be able to pull freely and on 5 there should be enough resistance. If this is the case your machine should sew perfectly.
Hope this help
Top Brother Sewing Machines Experts
Mike Cairns
Mike Cairns
Paul Bade
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
