I tried to clean my "self cleaning" oven and F9 continues to pop up. The oven door locks, but doesn't clean and beeping continues until I cancel the cleaning.
Thanks.
Go online to www.Frigidaire .com and you can enter your model # and download the manual.
But I think that this problem will be solved only by service!
A & E factory service is good and nation wide!
1-800-905-9505
They answer 24/7
Thank you Neil
PS.Please do not forget to give me a problem solved rating
www.shopyourway.com > Manage My Life > Questions Oct 26, 2009 - My Frigidaire oven, model feb24s5asb, door is locked and says f9. The door locked is beeping, I need code to know what the code means and how to unlock it.How do I reset an f9, door ... F-9 Error Possible causes: Door motor failure/jammed. Latch motor switch failure. ... Frigidaire Ovens Gallery 30 in.
Thanks for using FixYa. F9 error in your oven/range indicates an issue with the door locks assembly and/or the door latch. To start with check the door lock circuit, you can also try to jump start it to see if it's working. If it's not working then the Electronic Range control has gone bad and should be replaced, if it is working then the door lock circuit should be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
The F9 code indicates there is a problem with the door lock.
Try disconnecting the power to the range for 10 seconds and reconnecting. Open the oven door and hold the door switch plunger in while you try these things. Put the control into clean for 5 minutes then cancel clean. You must hold the door switch plunger in for the 5 minutes.
Try canceling the clean cycle without putting the control into clean.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^%$%^@#
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question@#$%^
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question$$%^^%$
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^%$@#$%
I have a similar problem with my electric Frigidaire convection oven, which flashes ERR F9 and beeps after finishing a cleaning cycle; if you haven't had to have it repaired professionally by now you might try cutting the circuit breaker to the oven for a few seconds and then turning it back on. My oven takes a few minutes to reset, after the circuit is turned back on, but then will unlock the door and let me reset the clock and continue cooking as normal. . . until the next time I set the clean cycle.
HI, your model number confirms that your range was manufactured by WCI (Frigidaire). although this doesn't help you now, it may help if parts are needed.
now, there is an indepth guide online to fixing this common problem and I would like you to go through it and see if it helps you solve your problem.
http://www.applianceaid.com/clean-lock.html
If you have found this site previously then I apologise, if you still need help, by all means post again and someone more qualified may help.
Press the self-clean button. The panel becomes blank(---), then press the up arrow( ^ ). The panel will appear 3:00 (indication for the duration of self-cleaning). The oven will lock on its own and start the self-cleaning. Good luck, ya'll!
