Dell Studio 17 Laptop Logo
Posted on Feb 19, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I cant a num lock key on my key board - Dell Studio 17 Laptop
Anonymous
Level 2:
New Friend:
  • Expert 71 Answers
  • Posted on Feb 19, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
71
Questions
0
Helped
6153
Points
207
Press together "fn" key and "NumLk" key..
Cant get the numbers to work on right side of key board
Numlocks turned on in your BIOS.
Or just a keypad issue where it states NUM LOCK
You may have to consult your owners manual to find out what key sequence is used to get into it.
Be very careful in the BIOS.
2answers
I cant figure out how to turn off number lock
You do so through the num lock key
If there is no num lock key then number lock being on shouldn't be a problem
3helpful
2answers
Need to find list/definitions of "function Keys"
Please open this LINK, scroll down to page no. 2-5 i.e. the section with "To use the Function Hot Keys Fn". There you'll find the details about the functional function keys of your compaq. It seems your function key i.e. Fn key is activated, to deactivate, press and hold down the Fn key while you tap the Numlock key once.
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
I dont know how my num locks got locked, but i cant unlock them
Look for a num lock key, or look for a little circle that says Num Lock. Hold "FN" key and press it.
The keys for numerals 1,2,3,4,7,8,9,0 do not work.
check fo te num lock key.. If only it is turned on you will be able to type the numbers.. or else you cannot..
so please try turning on the on the number lock by pressing the num lock key on your key board
2answers
The number keys will not work on my key board they were turned off some how. how can I turn them back on?
if there is nothing wrong with the keyboard..than press num lock to make them work again ...(the first led should be always lit to work )the num lock ..is the button in the left upper corner of the digits area..
18helpful
4answers
My laptop does no more boot up. As soon as i start , the caps lock and the scroll lock lights keep flashing continuously and the fan even does not run.
Well hellonihar, As far as your issue is concerned it seems to be some hardware issue. LED
Component
Error Condition
Blinking battery power LED
Battery
Insufficient charge on the battery
Blink: 1 - Caps Lock/Num Lock
CPU
CPU not functional
Blink: 2 - Caps Lock/Num Lock
BIOS
BIOS corruption failure
Blink: 3 - Caps Lock/Num Lock
Memory
Module error not functional
Blink: 4 - Caps Lock/Num Lock
Graphics
Graphics controller not functional
Blink: 5 - Caps Lock/Num Lock
System board
General system board failure
Blink: 6 - Caps Lock/Num Lock
BIOS
BIOS authentication failure
6helpful
2answers
When I press certain keys like P I get 6
This is yoru number lock function
look along the "F" key row for the NumLk or picture of the number 1 in a square. then hold down the Fn key on the lower left of the board. press the "F" key that corresponds to it and this will disable it.
2answers
Keying numbers instead of letters whun num lock on
Check 2nd Function keys. The problem you describe is normally a Fn +numlock keystroke on most systems
Num an scroll lights on on key board
same happened to me. restarted my computer and it went back to normal. except for the light above the key is still on
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
