My tv button lamp is blinking red I purchased a new lamp and installed it. I try to turn on the tv n its still not working can u help me fix this problem??
Lamp lifetime is not 100% predictable. A lamp may fail without notice, although this is not usually the case. The picture is more likely to become noticeably dimmer as the lamp nears the end of its lifetime.
While there is nothing wrong with using a lamp until it fails, some customers may want to purchase a new lamp and replace the existing one when they notice that it is aging.
If the lamp fails in a Mitsubishi MicroDisplay TV, there will be no picture on the screen and a red front panel LED indicator will illuminate.
62" mitsuabishi WD62525 had it over 5yrs now, we have been changed lamps three times,(geee lots money!!!)it worked ontill now...
two weeks ago blinking red lamp light was on , i thought lights out again so soon, i order new lamp, i cant turn on TV but blinking green timer light, TV is not working, try reset botton, turn off TV few days.
Please help
Lilly
You need to replace the power supply board. The new ones have a bigger heat sink - obviously JVC knows about the problem because they made the new ones bigger. It cost $250 from JVC and I installed it myself - took about 3 hours to do. If you are not tech savvy call a repairman. Hope this helps.
I found the following suggestion on avsforum.com and it worked perfectly (going through the lamp door).
Nate
Quote:
Originally Posted by Civicsixxx
After
some digging around I found that four blinks means there's a problem
with a fan. I took the back cover off, used a screw driver to manually
spin the fan near the lamp a few revolutions, plugged it back in and it
powered right up! I guess it was just stuck or something.
I'm a longtime lurker not much of a poster, but this happened to
me to yesterday. I used civicsixxx's advice and this works. However you
don't have to take anything apart. All I did was take out the lamp then
put your hand in carefully to the right and you'l feel the fan just
give it a spin and plug back in the light and the TV your good to go.
Hope this helps.
You really should give make & model number when posting, it helps us immensely, your lamp and possibly the ballast is bad, start with a new lamp first, odds are very good that it will fix your problem, can`t help more without manufacturer and model number, good luck, ps, order the original lamp, generics are junk and a waste of your money.
I think this sounds like my problem (need to replace the projector lamp). However, when I hit the "on" button, my SXRD 50" blinks green for about a minute then starts blinking red. Can you confirm the bulb solution? I was very pleased with this sight when my fan malfunctioned. I got the fan in a matter of day's from Sony and it fixed that problem.
Sounds as you have a bad ballest. The ballest is the power supply that turns your lamp on.
You can check your lamp by removing it and it should be clear and no broken pieces of glass.
With the lamp removed install the cover and turn it on you should hear no noise and when the power light turns red you should see a LAMP red led blink every 5 seconds. If no noise then the lamp is bad. If you do hear noise you have a bad ballist.
Hope this helps.
Frank
