SOURCE: DOES GA-945GCM-S2C SOCKET LGA775 SUPPORTS 500GB
GA-945GCM-S2C
Memory Support:
__2x1.8V DDR2 DIMM sockets supporting up to 4 Gb of system memory.
Note:Due to Windows Vista/XP 32-bit operating system limitation, when more than 4 GB of physical
memory is installed, the actual memory size displayed will be less than 4 GB.
__Support for DDR2 667/533/400 Mhz memory modules.
Note:Use of a 1066/800 MHz FSB CPU is required if you wish to install DDR2 667 MHz memory!
Storage:
South Bridge:
- 1 x IDE connector supporting ATA-100/66/33 and up to 2 IDE devices
- 4 x SATA 3Gb/s connectors supporting up to 4 SATA 3Gb/s devices
iTE IT8718 chip:
- 1 x floppy disk drive connector supporting up to 1 floppy disk drive
SOURCE: Please help me how to
Check out page 26 of the manual.....
http://download.gigabyte.us/FileList/Manual/motherboard_manual_ga-945gcm-s2l%28s2c%29_e.pdf
SOURCE: hi my friend: please help me
This motherboard suports SATA (Serial ATA 3Gbps) meaning that it is compatible with any SATA hard drive. A 2TB (Tera Byte) hard drive is the highest capacity available on the market. This motherboard has 4 SATA connections so you can put up to 4 SATA hard drives into it.
SOURCE: Is my Intel GA-945GCM-S2L Motherboard
no it can't, but it depends on your price range. this a good card for you and its pretty cheap also.
JATON VIDEO-PX558-DT GeForce 8400 GS 512MB 64-bit DDR2 PCI Express x16 Video Card
SOURCE: can 500gd hard disk be
Yes you can, there won't be any problem install 500GB hard disk on your motherboard. It is recommended to use SATA type Hard Disk Drive instead of the old IDE/ATA.
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
