Our Sole F63 treadmill is not running. It turns on fine, but it won't start. The display works fine, but none of the programs and the start button will work. Help!?
low speed is displayed on the display and the motor does not turn the treadmill. is there a motor reset button on the treadmill?low speed is displayed on the display and the motor does not turn the treadmill. is there a motor reset button on the treadmill?
You can't post conmments that contain an email address.
please perform a factory reset on your machine and check that all keys function once this has been done. Then, you can attempt to start your machine again. If the keys don't function after the reset, then you'll need to schedule a repair for those. Thank you.
You have a needle in your F63 Treadmill? This is why we ask for full;
make model (what is is) in all questions. The Search query will be that and the word 'manual'.
PDF
F63. -3-. WARNING - Read all instructions before using this appliance. DANGER - To reduce the risk of electric shock disconnect your Sole treadmill from the.
PDF
The F63 / F65 have ten built-in programs: one Manual program (PO. P1-P5),. U1 & U2) and two Heart Rate Control programs (H1 & H2). SPEED. INCLINE. P1. P2.
If you wish to get some details about treadmill repair and error codes ; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
'1.If the belt moves, but stops after a short time and
thedisplay shows "LS", run calibration. (on next page)
2.If you press start and the belt never moves, then
the display shows LS, contact service.
There are a few things you may need to check. You already tried calibration. Next thing I would do is check the sensor wire from the incline to the controller. Make sure its properly plugged into the controller. The controller can also be an issue. If someone was tampering with the unit, the sensor wire could be plugged into the wrong connector as there is another connector that will fit. You may contact me for phone support or sign up for phone support at Treadmill Repair Fitness Equipment Repair Parts Services Fitness...
please LUBE the deck belt+ rollers bearings too. You must do it evey 150 miles apros. This happen because the lack of maintenance schedule. God bless you
