If you cannot change it from auto. to manual it doesn't mean you need a new oven. The electronic timer can be by-passed fairly easily by joining the active and oven load wire together..
Testimonial: "Fab... just done the necessary changes - connected blue & red wires on LHS (as you view from the front) and hey presto all is working :-) thanks"
The electronic timer normally has 3 wires going to it. One is an active to give it power and the 2nd is a neutral to run the timer unit. The 3rd is the load which is for the oven. You will have to remove the back off the oven. Trace the wire which runs back to the main active terminal or fuse. This is obviously the active. The neutral will run back to the main neutral or will tap off another neutral which will eventually run back to the main neutral. The load will go straight to the oven thermostat. If you still want the timer to work piggyback off the active and loop over to the load wire and piggyback onto that one using spade terminals. If you dont need the timer just remove the active and load and join them straight together. Just make sure the connection is insulated somehow.
Thanks Blackmar, Could be the answer I'm looking for...
I'm a fairly competent DIY-er but not an electrician. I'm assuming this is bypassing the control mechanism of 'Auto' which sounds like a good idea. I'm thinking I'll have to take the oven out of it's 'built-under' housing to get at these wires. But do you know where the active and oven load wires are, in relation to the layout of the oven and what colours they are? (as I doubt they'll be labelled). Thanks again.
