Dryers Logo
Posted on Feb 07, 2011
My beko condenser tumble dryer is drying fine but is making a loud scraping noise. When I took out the clothes there was a strip of white felt in the washing
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 12, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1514
Points
Looks daunting to start with but just done mine,
remove top and all rear covers and rear panel after removing drum split washer, pump hoses, belt and elec connection, remove the drum and you will see where the felt seal goes. i had some felt i cut to 12mm wide and siliconed it in place, left to dry for 6 hrs, now runs fine.
Anonymous
Level 1:
New Friend:
  • Posted on Sep 24, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1514
Points
10
I have a beko condencing dryer that makes a loude squealling noise when drying. nothing looks untoward in the inside what could it be????
My tricity bendix 220 tumble dryer is making a thumping noise when is has been on for more than 10 minutes
Yes, very fixable.
Worn rear bearing.
Worn drum slides which are at the front of the drum and made of oiled felt.
When you are drying clothes the drum is moving up and then thumping down. Open the door, can you move the drum up and down?
My Whirlpool AWZ233 clothes dryer keeps stopping before the clothes are dry.
check vent line and or clean vent line inside dryer, clean vent line. Felt is probably drum seal.
Whirlpool AWZ233 Tumble Dryer Parts
Beko DRVS6W tumble dryer squeaks when the drum comes to a halt
DRYER MAKES NOISES.
A loose or worn BELT can make funny noises
Or the idler pulley that puts tension on the dryer drum drive belt could be worn out. If the pulley is bad we recommend also replacing the belt.
The glides on drum worn and making metal to metal contact.
The drum slides or glides support the front of the drum. As the drum rotates over the years, the glides wear out and then the dryer makes noise. Replace all of the glides as a set if they are worn out.
CHECK FOR LOOSE BELLOES inside the drum
Sometimes an item can get stuck inbetween the drum and the housing and scrape and grind making funny noises, things like coins, bra wire, nails, hair pins, etc sometimes u can just remove the cabinet and observe by turning the drum by hand or looking for scratch or scrape marks on housing.
The blower:
Clumps of lint, socks, and other small articles of clothing can get past the lint filter and into the blower wheel. If the dryer makes noise, and the noise seems to be at a very fast pace, there might be something caught in the blower wheel. In addition, the blower wheel sleeve might be worn out, allowing the blower wheel to wobble on the motor shaft. If this happens, replace the blower wheel.
The bearings:
The drum bearing supports the rear of the dryer drum. If the dryer makes noise this bearing might be worn out. Replace the bearing if it is worn out. Do not lubricate the bearing, the lubrication will attract lint and dirt and accelerate the wearing process.
The bearings TEST by moving drum by hand u may be able to feel loose or rough movement. And listen to sounds when turning it.
The drum rollers or castors:
It is very common for dryer drum rollers to wear out. If the dryer makes noise, particularly a loud rumbling noise, one or more of the rollers may be worn out. After removing the drum from the dryer, inspect the rollers.
Check for cracks, dryness, or damage and not engaging drum properly. Sometimes u can use high density LITHIUM BASE gear grease to re oil/grease them.
GOD IS GOOD !!!!
2answers
New Beko DRVS73W tumble dryer drum only moves in one direction and makes terrible noise
check the belt that goes around the drum to be correctly mounted at the motor area also inspect the rollers that hold and turn the drum
1helpful
Beko DRVS 62 W Tumble Dryer Squeakig
I had a problem similar to this on my Frigidaire dryer. I found that there is a felt ring that goes around the drum inside. This acts like a washer to prevent the drum from rubbing on the housing. On mine, the felt somehow got pushed in some and the drum was squeeking as it rotated. I had to order a whole new drum and replace it since on my model it was part of the drum.
Feb 11, 2014 • Dryers
Got new tmbledryer week old no digital display checked fuse on plug
Cheapest price search results for AEG T58840- Tumble dryer- Technical details, features, compare prices, AEG T58840 buying guide, reviews, tests, d and buy a AEG Lavatherm T58840 Electric Dryer from 419 at Deal Time UK.See images, features, check best price and 2 reviews and ratings by people who have bought this Aeg T58840: "A lot quieter than my old tumble pare prices for the AEG T58840 Washer d impartial reviews and buy online for speedy delivery only denser tumble dryer with Silent pare the UK's best prices for AEG T58840 and other Washer-Dryers from 100s of online shops.
AEG T58840 AEG Tumble Dryer Condenser, FREE DELIVERY, Buyers and Sellers offer the widest range of domestic appliances from top of the range to budget items at the most.7Kg Drying Load, Condenser Dryer, Sensor Drying, Large LCD scree, 20hr Delay rn everything you need to know about tumble pride ourselves on our customer service and the best prices on internet for the AEG Appliances Tumble Dryer Condenser Freestanding T58840 from BHS pare prices from across the web and read product reviews on AEG Lavatherm t58840 compare prices on Aeg t58840 from online T58840 Condencer Dryer- 7kg Load in White.
T58840: 7Kg Condenser Tumble Dryer in White: 433.97: AEG: T88840: 7Kg Condenser Tumble Dryer in White: 535.00: AEG: T35850: Vented Tumble Dryer: 264.97: AEG: Electric Shop supply AEG T58840 7Kg Condenser Tumble Dryer in White from leading manufacturers at discounted T35850 Vented Tumble Dryer- Special T58840 review, price comparison and where to buy online at Compare Store Prices UK for cheap T58840 White Freestanding condenser tumble T58840 Condenser tumble Price: 448.85.Tumble Dryer Models from AEG: T35850; T58860; T88840; T58840.
Aeg T58840 Condenser Dryer, read the latest user reviews and compare prices on Aeg T58840 Condenser T58840 review, price comparison and where to buy online at Compare Store Prices UK for cheap T58840 Condencer Dryer- 7kg Load in T58840 from Chantry Digital AEG 7kg Load Condenser Dryer with White T58840 Colour WhiteManufacturer AEG7kg Drying LoadCondenser DryerSensor DryingLarge LCD Screen20hr Delay StartCondenser duct information and details for AEG Lavatherm T58840 Electric AEG T59800 Dryer is in stock at several UK k the green box and well make sure that more people get to.
Find out more about the amazing AEG Lavatherm T58840 tumble dryer condenser in p with dryer hotpoint tumble problem on AEG T58840 Condenser Tumble Dryer Electric and free tech support for dryer hotpoint tumble d out more about the amazing AEG Lavatherm T58840 tumble dryer condenser in rything you want to know about the T58840.491.00: NEW AEG T58840- MANUFACTURE a better deal by comparing prices on AEG T58840 Washing Machines to save money online and guarantee Christmas T58840 3) Tumble Dryer Spares and T58840 3) Parts- Page 2- Belt, Door, Drum, Filter, Seal, Heater, Hose, Knob, T58840 Tumble Dryers Condenser In White Aeg The number one appliance specialist in the UK.
Condenser Sensor dryer
Large LCD Display
Sensitive Option, Leisure Programme
21 programmes including Microfibre, Jeans, Bed Linen
Easy Iron, Extra Dry, Storage dry, Hand Iron
Machine Iron, Intensive Dry, Extra Dry, Wool Care etc
Large 36cm porthole opening
Interchangeable door hinge
Manual timer up to 40 minutes
Stainless steel drum with Internal Light
Drum Light
please comment on these on how helpful.
1helpful
My dryer is making loud screaching noises. Everytime I turn it on to dry clothes is makes very loud screaching noises.
Sounds like it needs what are called glides or felt. This is what keeps the metal drum from contacting the metal housing. If this is let go too long the drum can be ruined
Dec 01, 2009 • Dryers
Grinding scraping noise and metal strips in the dryer.
yeah id prob just go buy a new drier, cause that one sounds as though its dried its last piece of clothing
May 05, 2009 • Dryers
Top Dryers Experts
john h
