SOURCE: Green Light, no Display - Gateway FPD1730
It could be your LCD backlight giving you problems. With the computer on and the monitor power LED green shine a flashlight in the lower left hand corner of your screen. Look for the ?Start? button, if your backlight is not working you?ll see a faint ?start? button if you look closely. Depending on the monitor this is usually and economically repairable problem. Let us know if you have any other questions and please don?t forget to rate this posting.
SOURCE: Gateway 22" flatscreen monitor won't display after startup
Monitor has blown capacitors internally on the power board I can fix these let me know what you would like to do.
SOURCE: I am getting power and the monitor turns on and
It is a hardware problem. So you can repaired it from service center.
SOURCE: Is there any fast way to fix the monitor for
your lcd monitors smps is problem
change the smps from any monitor repair shop
ok bye
Testimonial: "thank you for solution"
SOURCE: Monitor appears to be in permanent standby mode -
Look for bad caps with bulging top in the power supply. I would replace all 10 with PANASONIC FM or FC series from DIGIKEY. Post back what you see inside so we can guide you further, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
