If you just upgraded memory and are having problems, the system memory is more than likely causing the problem. Try either taking out the new memory and leaving in the old (if you added a memory stick), or placing the old memory back in the computer and try starting up. Your memory could be either incompatible or it could not be seated properly.
So, if you replaced all of your memory in the upgrade, place the old memory back in and try to start up. If you added memory, then just remove the new piece you put in and try to start with only one card. I don't know how much memory you have.
Try this and let me know what happens.
Brian
