Ovens Logo
Posted on Jan 25, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a electric Whirlpool Oven (Accubake) that will not operate on bake or broil. The screen reads "locked" and shows a default code "EO" & F2. How do i clear it or do i need a part?
Anonymous
Level 2:
Sergeant:
Champion:
  • Expert 263 Answers
  • Posted on Jan 26, 2011
Anonymous
Expert
Level 2:
Sergeant:
Champion:
Answers
263
Questions
0
Helped
64666
Points
606
Shorted keypad is a common problem with Accubakes. So try replacing the touch pad.
Oven repair in Mission Viejo, CA
Appliance repair in Mission Viejo and Orange County, CA
Accubake oven broil on while bake is on
did u by any change do any work inside that may have reversed the wiring? other wise check the oven relay board and the wiring behind the bake broil switch
Whirlpool gas oven will not heat
most likely you have a bad ignitor,pull out the racks and remove the floor to the stove,turn on the bake,if the ignitor glows but it takes more than 40 seconds for the flame to light you have a bad ignitor even though it glows and if it doesn't glow at all the ignitor is bad,also if the broil lights on top and the bake doesn't change out the ignitor.next time send the model number and i can look up your machine to help you better.
Broiler element not working at all. checked element--it's OK. Called a serviceman-- he thought it was an oven sensor--replaced sensor ---no change Electronic clock some times shows a code "F2 ...
you do not say it is electric oven. if so broil element requires 240 vac. may be controlled by relay. Is bake element working? also controls for broil may be different setting if digital panel is in this design. I think same sensor may be used for bake or broil.
you do not say if gas oven, electric oven, single or double oven or if digital panel control, a little more information would help.
if you have digial voltmeter, FULLY disconnect electric power and measure element on terminals. probably less than 15-20 ohms for a good element.
Dec 28, 2010 • Ovens
When the oven is set, it heats for about five minutes. Then "F-2" appears on the screen and it shuts itself off completely.
F2 Oven temperature is too high
1. Look for welded relay contacts on bake or broil relays. If this happens, replace oven control (also called clock or ERC).
2. For SELF CLEAN models: check door lock operation.
3. Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective.
I have a whirlpool Super Capacity 465 self cleaning oven with accubake. About a month ago after using the oven to bake dinner the keypad button(s) became stuck (i figured this out after researching the...
Hello Michelle!
Crazy to hear, but this is actually a touchpad failure.
Luckily, we at FixYourboard.com have a solution.
Read more about the cause and fix in our blog! F5 E1 Error Code Whirlpool Built In Double Wall Oven
Feel free to contact us if you have any questions. [email protected]
My oven will not turn on or off.....the fan is running and the screen is showing F 02
HI, the F-2 is signaling a higher than normal oven temperature. Follow these steps bellow.
2. For SELF CLEAN models: check door lock operation. If the door lock device is not working properly, replace.
Remember: Oven control (ERC) measures resistance of sensor circuit, not actual oven temperature.
31helpful
3answers
Getting oven back on fahrenheit instead of celsius
Actually for the Whirlpool Accubake I just figured out, the bake button didn't work, but holding the broil button did the trick.
Apr 19, 2009 • Ovens
1helpful
3answers
Whirlpool Accubake oven super capacity series 465
In an attempt to self clean my oven, I pushed the auto clean button and then pressed start. Instead, nothing happened, but now have a message on the panel reading E1on the left side of panel and -F5- on the right side of panel. I am unable to clear it or operate the oven now.
Top Whirlpool Ovens Experts
ZJ Limited
ZJ Limited
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
