SOURCE: we are trying to install a 2 speed 3 horsepower
the instruction come with the relay ? be care full
SOURCE: We have an AquaLink RS4 All Button control in the
can't be made the only is to cancel the delay on the back dip #4 heater cool down turn off breaker when do this also change assign jva at system setup
SOURCE: Jandy Aqualink rs4 when set on auto the system
Go through your menu again and reset. These have defaults that may be causing the trouble if the power went out or your battery backup is old. Check this and let me know and we can look further. Your menu should help to walk you through problems, it is very user friendly. Hope this helps, let me know.
if using a dimmer go to set up highlight dimmer
