20 Most Recent Jandy AQUALINK RS TELELINK KIT Questions & Answers
I cannot figure out in the RS6 menu how to delete
The best thing you can do is to clear the memory for the system this should be done once in awhile it is like rebooting your computer.
Here are the steps;
1. Press the menu button
2. Now press < button till System Setup is displayed
3. Press enter
4. Press < till "Clear Memory" is displayed
5. Press Enter
6. Press Enter
You will get a message saying " System Memory is being Cleared"
Once it is done the display will go back to scrolling mode
Now reprogram the system as you normally would
You should do this "rebooting" once a year it will make the system run alot better.
Aqualink systems can get a issue called "Ghosting" which is equipment will get programed to run all on it's own. We see it alot in the bigger systems (RS8 and up) for some reason. We are a Jandy warranty center have been for 10 years now.
Hope this helps
6/10/2021 8:51:53 PM • Jandy AQUALINK... • Answered on Jun 10, 2021
2answers
Jandy aqualink RS PDA does not show salt level or
filter pump must be on and go to devices on you should be able to turn on aquapure make sure 4 pin is connected to aqualink
3/20/2018 6:46:33 AM • Jandy AQUALINK... • Answered on Mar 20, 2018
New pool pump installed is not responding to jandy Is there a set up or reset we need to do?
Need more info. Model and voltage to unit. Is it connected to automation?
10/16/2017 4:06:52 AM • Jandy AQUALINK... • Answered on Oct 16, 2017
We have an Jandy Ji8000.
Look up Zodiac Pool systems, on the web site you can find a list of service providers in your area. You may be looking at replacing your automation at this point.
5/14/2017 11:50:02 AM • Jandy AQUALINK... • Answered on May 14, 2017
2answers
How do you drain the spa?
There is probably a drain valve somewhere near the control panel ... forgetabout it ... too slow.
Best way is to get a small pump and pump it away. Next best is wet dry (shop vac). My favorite is siphon ... dont have to buy anything or drag anything out ... only a hose. By the time my water is out ... I have had time to do the necessary surface cleaning and waxing.
7/13/2016 10:30:37 AM • Jandy AQUALINK... • Answered on Jul 13, 2016
0answers
0answers
0answers
0answers
Jandy AQUALINK RS TELELINK KIT  Logo
179 questions posted
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
ZJ Limited
ZJ Limited
john h
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
View Most Popular
Jandy Pool & Spa
  • Jandy Pool & Spa
Most Popular Question
water temp keeps showing 197 or higher
  • Pool & Spa
