CD changer does not work anymore. Loaded the magazine with CDs. The screen displayed "CD ERROR" at first. I unloaded the magazine, changed the CDs, reloaded. Now the error message displays "NO MAGAZINE" and the changer will no longer eject the magazine. A faint electric motor sound can be heard when pressing the eject motor. Thanks for any help.
Hi Open top cover, if the empty magazine was left inside the cd trays it can slide out into the playing area and jam the unit, check it like that anyhow. Sometimes you can see a small metal tab to release the magazine. However Error1 means Battery inside CD Changer needs to be replaced. And NO CD.CD error message means No CD in magazine or no magazine in CD Changer.
To fix the problem, disconnect the CD changer. take off the top plastic slide cover, with a small screwdriver slowly move the gearing so that the CD disc holder will move back to the load - unload position. Pop out the CD holder. Replace unit, reconnect the optic and power lead, switch on radio and the unit will work again. grease the moving parts with light lubricant.
CD player is not working. Motor will not unload or load discs. It will play CDs fine but cannot change them. Unit will need to be repaired by an audio specialoist or replaced.
CD ERROR DISPLAYS
CD Changers
E01:
The disc magazine is not inserted in the cd changer
E02:
No disc is inserted in the disc magazine
E04:
The disc is dirty, or the disc is inserted into the disc magazine
upside down
E99 RESET PROCEDURE:
Remove CD magazine by pressing eject button on changer.
Remove all discs from magazine and re-load empty magazine into
changer. Using the Radio RESET CD system by pressing and
holding the “ON”/”POWER” button for about ten seconds, or in
earlier models the “EJECT/6” button.
FM/RF Remote Controls
E99 RESET PROCEDURE FOR REMOTES:
Remove disc magazine from changer by pressing eject button.
changer. Press RESET button on interface unit
WAIT:
The temperature is exceeding more than 55c(130f) and the cd
changer cannot be operated. When the cd changer cools off, this
wait disappears. When the RESET button on the interface unit is
pressed, this WAIT appears for a few seconds.
IF THESE ERROR CODES STILL KEEP APPEARING
CONTACT YOUR DEALER.
CD ERROR DISPLAYS
CD Changers
E01:
E02:
E04:
upside down
WAIT:
CD Changer Error Codes:
If problems arise during CD changer operation, the following error codes may appear in the display: ER-1: No magazine loaded. ER-2: Problem in the disc loading function. ER-3: Error in the disc loading function. ER-4: Error in the disc unloading function. ER-5: Error in the magazine position. ER-6: Error in the laser pickup position. ER-7: Error in the laser focus on the disc.
CDAC ER2 usually means a cd is stuck, not reading properly, or that the magazine is stuck or broken. take out all cds and try it with a known good cd (one that played ok in the past). if that doesn't work, try unplugging the unit and plugging it back in.
if it still doesnt work, take the magazine out, power it up so that you get the "no mag" error, then insert the magazine with no discs and see if it still errors out with ER2. if it does, then the magazine is bad, or the changer is bad..
if it works, then try the known good disc again, if it works now, your magazine was probably stuck, or one of the other cd's isn't liked by the changer.
