are you sure that the solenoid is not working
mostly they do work but the spring at the flap hinge breaks and then the flap will not move or be easily opened
the requirement is 2 people --one to hold the button depressed and the other to use a pry bar or suitable tool to open the flap.
You have listed the vehicle is a 1987 Jaguar XJ6. The trunk is not electronic and only unlocks with the key as well as both the gas doors. Any issues here then it is your key or the actual trunk latch. If you do have a 1988 model year then the trunk lock has 3 positions. locked all the time, unlocked all the time or the vertical position locks and unlocks with the vehicles drivers door lock. If the trunk button (paddle) is loose and moves but nothing happens then the inside rod has come loose and you will have to manually operate the latch by removing the license plate and taking a long screw driver through the lower plastic bungs. The fuel flap is a separate unite and does have a manual release but you need to open the trunk to get to it. If the fuel flap stays locked all the time then the actually filler neck module will need replacing.If you have a 1997 which has the electronic release button to open the trunk (95-2003) Then you will need to firstly lock all door and unlock the drivers door 2 times. Check the fuel flap is now released, if not then the fuel flap actuator located on the filler neck inside the trunk is bad. If the trunk does not open with the remote, inside car switch and trunk mounted switch then the passenger side trunk harness is broken. Open the trunk with the key and on the right(passenger) hinge there is a grey plastic cover, remove that cover and carefully peel back the wiring harness cover and you will find 1 or more broken wires. Once the wires are repaired then I recommend you zip tie them in place and retest the trunk release button.If this does not answer any of your questions please feel free to email [email protected]
If you are refering to the fuel flap this locks and unlocks with the central locking and they tend to jam. Go inside the boot and remove the carpet at the side of your fuel filler and you will se a cord, pull this and your flap will open.
you will need to force the flap open. inside there will be a bar that pops out to lock the flap. this will come off with 2 screws and will need replaceing.
Push back release rod - 9 - by operating remote control unlock and remove bolt - 2 -.
Remove rubber part - 8 - from tank filler flange and swivel out tank flap unit - 1 - from side panel - 7 -.Assembly piece - 4 - and actuator - 6 - is installed.
Install tank flap unit - 1 - (rubber part rolled up) with hinge side first.
Bolt tank flap unit - 1 - and assembly piece - 4 - with bolt - 2 -.
Tightening torques: Bolts - 2 - 1.5 Nm
Remove side luggage compartment trim.
Disconnect harness connector at actuator - 6 -.
Remove actuator - 6 - using special tool Socket wrench T 10010 from angled mounting bracket.
Remove actuator - 6 - together with release rod - 9 - from seal - 5 - and assembly piece - 4 -.
Installing Installation is reverse of removal. Tightening torques: Bolts for actuator - 6 - 1.5 Nm .
hi if you look into filler pipe you will see a flap/restrictor just inside this is to prevent wron fuel filler nozzle from entering so unless you put the correct fuel nozzle fully into tank fill pipe and this pushes flap open you will experience slow filling ALSO? to put fuel in tank the air inside must be able to displace emit from tank ok this is done via a hose from tank and is usually clipped along side the filler pipe under wheel arch below filler check and ensure this pipe is clear and also free from kinks? as this if blocked will not allow displacement of air from tank as fuel level increases? hope this is clear enough for you to understand?
hi from uk are you putting the fuel pump gun/nozzle fully into tank filler? as there is a flap valve inside the tank filler neck and unless nozzle pushes this flap open it will restrict flow of fuel into tank one other cause of problem slow filling? is the ventilation pipe from the tank which is positiond along side of fill pipe ? may be kinked or blocked at outlet look under car where filler is and check? as fuel enters tank it displaces air from tank via this vent pipe? hope this helps you solve problem
