My model of samsung LCD is Series 5 (LA40B530).It has a usb slot but it neither run any media files or pictures nor it detects any usb attached to LCD.What should I do? Do i have to update the software?
No.The only use of that USB is specifically for firmware upgrade use. I'am not sure why you rated my response as not helpful if your manual says its only good for firmware.No.The only use of that USB is specifically for firmware upgrade use. I'am not sure why you rated my response as not helpful if your manual says its only good for firmware.
You can't post conmments that contain an email address.
try connecting tv to cable direct also try unplugging both converter and tv for wile like 5 mins plug both back in see if tv and converter sync, but if otherwise then The ysus board is the most common reason. you can try websites on ebay.com to buy parts for replacement...
If you are looking for drivers for moving, adding/removing pictures or mp3's try this.
Transfer MP3 to M300 without driver
While in standby mode, plug in the USB cable to the handset and connect it to a USB port on your PC
While in standby mode, press the Menu/OK key
Select Tools (9)
Select Mass Storage (1)
Select Connect to PC (1)
The handset should display the message, Connected to PC & Call Disabled
Open Windows Media Player 10 on your PC and select the SYNC option
The left-hand side of the Windows Media Player will display the files on your PC, Check the songs you want to download
Press the Start Sync button on the upper left-hand side of the Windows Media Player
A Synchronization Complete message will appear on the phone when downloading is complete.
To return to standby mode, press the left soft key for Done then select Yes (1)
Disconnect the USB cable from the handset & PC
Transfer Pictures and Video without driver
Insert a microSD memory card into the handsets microSD card slot Connect the USB cable to a USB port on the PC
Insert the remaining end of the USB cable into the handsets power interface connector
If necessary, complete the [Found New Hardware] wizard on the PC (The PC will display [New Device Detected] and a new drive letter will be assigned for the handset)
Select Tools (9)
Select Connect to PC (1), if the handset has established an active connection to the PC, the LCD will display [Connected to PC & Call disabled]
Browse to the file(s) location on the PC & copy the file(s)
Open the new drive letter (Removable Disk) for the handsets memory card
Create a folder named DCIM then create a subfolder within the DCIM folder named 100SSMED
Paste the file(s) into the DCIMs 100SSMED folder
When you have copied & pasted all desired content press the left soft key for Done
Select Yes (1)
Disconnect the USB cable from both the PC & handset
You will now be able to view the file(s) from the microSD memory card
Or if you need the driver for other reasons I managed to find a link that works and is free for you. :)
Since that you already used different computer still its not detecting the camera It means the problem is either On the USB cable itself or on the camera USB slot. Because windows XP vista or Windows 7 has a generic driver for all the camera it should detect all the camera thats been inserted on the CPU.
try to used different USB cable and make sure the USB cable is MODEL U-8 thats the right cable for your camera
Before transferring digital images through the USB Connection, you must install the driver and software that came with your camcorder. The software may vary by model. Please view the attached instructions and system requirements for installing the software. Instructions for transferring images through DVC media are provided on the disk as well.
For newer models, you can use Windows Explorer to transfer still images. After installing the driver as instructed in the attachment, follow these instructions.
1. Connect one end of the USB Cable to the Camcorder.
2. Connect the other end of the USB Cable to the PC
3. Power on the Camcorder. (You will notice a green arrow appear in the lower right hand corner of your monitor indicating the device has been detected by your PC)
4. Right click the 'Start' button and choose 'Explore'
5. The Camcorder will appear as a 'Removable Disk' with a drive letter.
6. Click on the Removable Disk and two folders will appear. DCIM and SSMOV. DCIM will contain still images. (SSMOV will contain mpeg's)
7. Double Click the DCIM folder
8. Double Click the folder named 100SSDVC
9. All pictures on the memory stick will appear.
10. You can highlight any (or all) pictures you would like to transfer and move or copy to them to the folder of your choice. (You can select a folder in the left window pane of Windows Explorer and drag and drop files as well)
11. When you are through, you must 'Safely Disconnect' the camcorder by right clicking the green arrow in the lower right hand corner of your screen. (Follow the on screen instructions. Failure to do so may result in flash memory loss)
If i update the software,will i be able to play media files on it?
