This set does have a hard reset which is done with the original Mitsubishi remote, confirm actual model number and I will tell you how to do it.
It will return the set to the condition it was when new in the box, all labels on inputs will be gone, set should then come on channel three in AIR band; YOU HAVE TO AUTOPROGRAM it and put into cable band if using that.
Let me know model number.
SD TECH
Testimonial: "Thank you so much. Up and running."
This model is WAS-55859. Unable to make changes with the remote audio also. If reset, I am assuming that I will not be able to hook up to theater sound system, because I will not be able to turn speakers off? Thank you so much for your help....
I presume is WS-55859?
Hard reset for that model with set on and Mitsubishi remote is Menu, 0,1,7,0 and enter.
SET/UP EXIT
Hit the "+" quite a few
times until you get to "MEDIA POWERUP"
Hit SELECT
Use the +/- keys to
enter the password (1234)
Hit SELECT - you should
see a small - and + button on the screen
on either side of MEDIA POWERUP (if not,
repeat previous steps)
Hit the + sign until
you get to NO MOTION
Hit SELECT to exit
MEDIA POWERUP
Hit the + button to go
to the next item HEAD CLOSE
Hit SET/UP EXIT to save
changes (permanently)
Open and close the printhead to check to see if it worked!!!
