My miele w1926 water valve keeps running all the time no matter what cycle i choose,if i disconnect the water valve it shuts down,so it is beeing commanded to come on fromt somewere,the question what is commanding it all the time
1 Remove stacking kit from top of unit.
2 Reatach the two plastic clips to the back of washer.
3 engage the two slots on the washer top into the clips , pull forward drop lid down on top of washer then secure with two screws on either side of lid.
hi - If I remember correctly this particular series had a time related sequence built into the programme, whats happening is the timer has picked up the false readings when the pressure activates the switch.
Suggestions to look into - leave power off & turn water back on - does water run into the machine (faulty valve); turn power on initiate a cycle water runs, then turn power off - is water still running? (faulty valve)
From experiences on the field, theres a slim chance that the pressure tube has a hole in it from the vibrations over time. This effect will not create enough pressure in the tube to activate the pressure switch, the only other problem would be the pressure switch itself.
Hi Yugin.That indicates your machines water inlet valve is faulty.(Means it's taking less water then normal)Please check this steps & do it fast before water inlet is finishes:1-Turn your machine on & run empty with pre-wash cycle first.2-Please ajar the detergent drawer & check runing water on compartment one 3-Please press pre-wash button & compare the running water volume on compartment two.If the running water volume 1 is less then 2 or vs.water valve needs to be replace.That's causing problem.I hope that helps.Thanks.
Hi dear.It sounds like you'll need to change water inlet valve very soon.Because,machine waiting water level to be reach,in specific time frame in chosen program parameters to be get completed.If that does not happen,then it starts giving fault indication.Indication stops after fill,because task been competed & computer disregards the fault.If that won't happen then machine going to get stop completely & indication will carry on.Chage the water inlet valve if you can.I hope that helps. Thanks.
Hi dear.According to what you're saying,It has faulty water inlet valve.Machine unable to get enough water to do it's cycle in given parameters in time period & starts giving error but before the cycle complates,however it takes enough water,that's why error lights goes off.If you can,you need to change the valve or call service department.I hope that helps.Thanks.
Hi Ekruijver.As I know USA electric standarts diffirent then New Zealand.Your machine should not be use in there unless if you purchase one of those step down transformer for it.That could not be inexpensive solution anyway.That can help.Please check this web site:http://www.tortech.com.au/category/595/ They might able to help you for this issue.OR MIELE NEW ZEALAND.Thanks.
That happened to me too. If the machine is a few years old and the hoses are not kinked it's possible the water inlet valve needs to be replaced. On this machine there is a triple cold water valve and a single hot water valve. Mine needed the triple valve and it is about $300 if I remember. Check to see if it's the cold or hot water valve by looking at the water filling through the soap drawer for cold or hot water cycles. When the valves go bad they run but the output is very low which causes the light to flash because it can't fill to the correct level.
You can get to the valves by taking off the top. If you don't feel comfortable working on your own machine have a professional do it.
