20 Most Recent
Miele G892SC SS Dishwasher Questions & Answers
The END, START/STOP & TOP SOLO all flash at same time Miele g892sc
I have a G851sci dishwasher. I finally found what the issue was when the End, Top Solo, and Start LEDs flash on and off randomly. It has to do with the wash cycle selector knob. This knob is connected to a 12-position rotary switch mounted on the circuit board inside the control panel. The problem is that the switch contacts are oxidized and are not making good contacts. So to fix this, you have to remove that circuit board from inside the control panel. I won't go into details on how to do that but once you have it out, you'll see the rotary switch made by Seuffer, a German electronics company that no longer exists as Seuffer. Luckily, this rotary switch can be taken apart without removing it from the board. There are four clips that must be bent out to remove the top part. Once you have this open, take a very fine 600 grit or higher sandpaper and remove the oxidation from all the metal contacts that are in there. Do the same for the wiper on the knob side that you pulled off. Once that's done, use a cotton swab with alcohol to remove dust and debris from the inside amd off the contacts. Now simply reassemble everything. This issue should now be gone. This issue is related to F03 fault code. The service manual, which you can find somewhere off the web, explains how to extract the fault codes from your machine. Hope this helps.
Where can I get Miele dishwasher parts?
hi,
you will have to purchase spare parts from Miele directly or from a miele authorised dealer. you cannot purchase spare parts any other way.
if you look at
www.miele.com and chose your country you will find your local Miele dealer or office
Replacement mounting bracket
You do not require brackets , DW can be secured thru the holes on side of washer as well as threw the inside top
Mounting bracket replacement
James - most Miele dishwashers are side mounted to the cabinet - what Model are you referring to and I can let you know.
Thanks
Hello , The inlet/drain light on my dishwasher
My G892SC is almost 10 years old and recently had the same problem. The machine seemed to be stuck in the drain cycle and the intake/drain light flashed. I called Miele and ran through a few diagnostic tests but nothing worked. I had a Miele certified technician come out to look at the problem and he told me the drain pump needed to be replaced and that it would cost about $500 for the part and labor. While researching the cost of a new dishwasher, I stumbled on some online discussions about this problem and someone suggested pressing all 4 lower buttons on the control panel at the same time. I tried it last night and it worked! I only ran the wash & hold cycle but will try a full cycle tonight.
982 error code miele
I don't have the same model but I found this on the web,2011-11-25_043923_g600__800_miele_service_manual.pdfIt should point you in the right direction.
