What you didn't say was whether it plays the high frequencies. If not, you may be looking at bad speakers. It's not the amp that's bad as you say that voice and whatever comes through. The amps either work or they don't. They don't care about the frequencies. All they care about is the input, and whether the amp works, or is distorted. If you play your systems too loud, you will eventually overdrive the tweeter and midranges, and burn them out.
You can always try the factory reset in your owner's manual. That may correct this. I would say that you might have a bad center channel, but you say that it plays in other languages just fine. Try the reset...
please double check your wiring again as if you cross the polaritys (+ and -) you put the audio signal out of phase, thus casing cancellaion of things such as voices.
+ to +
- to -
NOT
+ to -
