20 Most Recent
Samsung HT-X50 System Questions & Answers
Samsung HT-X50 DVD Audio Problem
I had this same problem and checked all of my cables and wires. Come to find out one of the wires that connected to the central audio speaker (the one that the audio track comes from) was unplugged. I plugged it in and that fixed it! My audio track is back! So make sure that all of the speaker cables are properly connected! That might be the source of your troubles!
Why does disc tray open randomly Samsung ht-em54c
I had the problem of the disk tray opening and closing randomly but finally fixed it. I went thru a number of steps so I don't know which combination or individual step fixed it but I think it was changing the HDMI cable from the TV to the Blu ray player that finally fixed the problem. Previous to that I had removed the disk player and got the audio to work with only the TV and used one of the HDMI inputs as the output from my PC. That way I could play DVDs on my PC and run it thru the player to get audio in the speakers and video on the TV. Every once in a while the tray would try to eject (even though the player was not there). Finally I changed the HDMI cable to an older cable, the one between the TV and the player and it started working! I then put the disk player back in the unit and it all worked, everything!! Good luck!
I was playing music and it just stopped playing.
Did the receiver shut off, or did it remain powered up?If the unit overheats, it will shut down. They can also shut down if the volume is maxed out. Most times when this occurs you can power down and wait 5 minutes to power it back up.What source was being used at the time it stopped transmitting sound?Have you tried to change sources?
Sound and no picture
are uusing hdmi out this is known for hdmi issues u could always run stuff direct to tv unless its dvd player u wann watch then back from tv to this digital coxial cable
Hi, we just bought a
First, is the unidentified TV the actual source of audio (self-tuning from the air) or does its programming actually originate externally, say, a Cable Box? What does the TV's manual say?
If the sound actually comes from an external source treat that source like any other hi-end audio component and attach its highest quailty audio directly to the HT according to ITS manual.
NO signal ever benefits from multiple connections or 'hops' and it gets expensive zig-zagging a signal all over the room. K-I-S-S is the word of the day. Run the BEST version of any signal directly from its source to the BEST electronics that will present it to you for consumption. The separation of audio and video inputs and outputs on a device is what allows and ENCOURAGES the direction of each signal to the BEST electronics that can process it. Example: your TV does not have the best speakers in the room so why send it any high-end audio?
Fan check issue
ya need to get fan fixed is safe mode cuse they genrate alot of heat have to have it in well vented area on a nice power strip like monster
