Memory Upgrade for Gateway GT5082 Computer, the Gateway GT5082
Computer takes the PC3200 DDR SDRAM DIMMs. Supports Dual Channel DDR. Memory
Type, and comes installed with 2.0 GB = 512 MB (removable) + 512 MB (removable) + 512 MB (removable) + 512 MB (removable) of Memory. You can upgrade your
Gateway GT5082 Computer to up to a maximum of 4.0 GB Memory, the system has 4 sockets to install Memory, already with 2.0 GB = 512 MB (removable) + 512 MB (removable) + 512 MB (removable) + 512 MB (removable) standard Memory installed.
For best Computer performance use the maximum amount of allowed Memory per slot for your Computer.
Choose the following Memory Upgrade for Gateway GT5082 Computer.
If you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules.
hope it helps
Dual-channel architecture requires a dual-channel-capable motherboard and two or more DDR, DDR2 SDRAM, or DDR3 SDRAM memory modules. The memory modules are installed into matching banks, which are usually color coded on the motherboard. These separate channels allow each memory module access to the memory controller, increasing throughput bandwidth. It is not required that identical modules be used, but this is often recommended for best dual-channel operation. It is possible to use a single-sided module of 512 MB and a double-sided module of 512 MB in dual-channel configuration, but how fast and stable it is depends on the memory controller.
If the motherboard has two pairs of differently colored DIMM sockets (the colors indicate which bank they belong to, bank 0 or bank 1), then one can place a matched pair of memory modules in bank 0, but a different-capacity pair of modules in bank 1, as long as they are of the same speed. Using this scheme, a pair of 1 GB memory modules in bank 0 and a pair of matched 512 MB modules in bank 1 would be acceptable for dual-channel operation.
Modules rated at different speeds can be run in dual-channel mode, although the motherboard will then run all memory modules at the speed of the slowest module. Some motherboards, however, have compatibility issues with certain brands or models of memory when attempting to use them in dual-channel mode. For this reason, it is generally advised to use identical pairs of memory modules, which is why most memory manufacturers now sell "kits" of matched-pair DIMMs. Several motherboard manufacturers only support configurations where a "matched pair" of modules are used. A matching pair needs to match in.
Good luck
Rate the solution if got help
This motherboard can support up to 2Gb of DDR266 RAM modules.
Attached is part of the memory detail from the manual.
If you need a copy of the manual. please click on this link to download :-
ftp://serwery.optimus.pl/Servers/Motherboards/SE7501BR2/Dokumenty/se7501br2tps.pdf
3.1.2.2 Memory Configuration
Memory interface between the MCH and DIMMs is 144 bits wide. This requires that two DIMMs
be populated per bank in order for the system to operate. At least one bank has to be populated
in order for the system to boot. If additional banks have less than two DIMMs, the memory for
that bank(s) will not be available to the system.
There are two banks of DIMMs, labeled Bank1 and Bank2. Bank1 contains DIMM locations
DIMM1A and DIMM1B and Bank2 contains DIMM2A and DIMM2B. DIMM socket identifiers are
marked with silk screen next to each DIMM socket on the baseboard. The sockets associated
with any given bank are located next to each other.
The baseboard's signal integrity is optimized when memory banks are populated in order.
Therefore, DIMM Bank1 must be populated before Bank2.
DIMM and memory configurations must adhere to the following:
• DDR266 DDR registered DIMM modules
• DIMM organization: x72 ECC
• Pin count: 184
• DIMM capacity: 128 MB, 256 MB, 512 MB, 1 GB, 2 GB
• Serial PD: JEDEC Rev 2.0
• Voltage options: 2.5 V (VDD/VDDQ)
• Interface: SSTL2
• Two DIMMs must be populated in a bank for a 144-bit wide memory data path
• One or two memory banks may be populated
Table 2. Memory Bank Labels
Memory DIMM Bank Row
J8D22 (DIMM 1A), J8D15 (DIMM 1B) 1 0, 1
J8D7 (DIMM 2A), J8D1 (DIMM 2B) 2 2, 3
Note: Memory must be installed in pairs; DIMM Bank1 must be populated before DIMM Bank2.
Memory within a DIMM bank must be identical; between banks only the DIMM size may be
different.
Functional Architecture Intel® Server Board SE7501BR2 Technical Product Specification
26 Revision 1.2
Intel Order Number C13977-003
Figure 3. Memory Bank Label Definition
system came with 512 I need at least 1gb to install windows 8.1 because next month there will be no more support fo windows xp. how do i do this?
