We had a technician come out and look at the TV. He replaced a board which was not the problem. He said the green tube was leaking and needed to be replaced. It had leaked on the board. He later said that Samsung no longer offered this part (the green picture tube) for this set. Has anyone else had this problem? I called Samsung and they stated they do offer the part. Repair center still stating part is obsolete. Any suggestions on what to do with this TV??? need new blue and green tubes
If there aren't any service parts available. I would suggest to click here to find more information or even get the CRTs rebuit by them.
Good Luck.
If the repair center is an authorized Samsung service center, they should be able to get hte part for you. I don't have parts listings for Samsung sets, but the part numbers should be available from Samsung directly. Since you know the problem, try another service center that is associated with Samsung. Not all independent servicers can get parts from all manufacturers.
Dan
SOURCE: need new green picture tube
You dont need a new tube. What you need is to repair the seal on your old tube and replace the CRT coolant fluid. There is a coolant chamber attached to the tube with long bolts with springs on them that contains coolant to prevent your tubes from getting hot. Yours may just need tightening, but I would replace the seal just to be safe as thecoolant can and will destroy your circuit board if its allowed to continue to leak on it.
