Lamba de?i?tirildiyse, Lamba balast?n?n en ?ok renk tekerle?i ve ard?ndan Dijital kart takip edece?ini dusunmekteyim. https://canlitv.center/tr adresinden dilediginiz televizyon kanallarini online olarak izleyebilirsiniz, kendinizi uzmeyin
The problem with the television is that the lamp is bad and need to be replaced. This is as a result, of overheating inside the unit of the television. Be sure to have your television where there is proper vent.
Try to unplug the television for a while before working on it as the television stores high voltage in it. Then you Turn to the back of the television, then you unscrew the television and assess the lamp of the television and replace it with a new one.
Reassemble the television back together and power it on. That way it will work properly.
