to tell if you have a stripped gear. take the cover off you should see a lot of white power in it. depending on the age of your opener buy or have both the gear and sprocket replaced.
This could be a few things:
1) Your clutch plates may have worn out so that even when the bike is in gear, it will just rev, but no power will be transmitted to the drive shaft (smaller front chain sprocket is the driving gear, larger rear sprocket on the back wheel is the driven gear)
2) The front chain drive sprocket has come off under the cover on the motor - if the chain is really slack, have a look.
3) The front chain drive sprocket SHAFT has sheared. (basically, meaning that the shaft has broken into two parts as it couldn't handle the drive power (torque) being delivered through it to the chain drive) With the motor on, listen for grinding noises internally
when you rev, from the vicinity of the front chain drive cover. If its rough and grindy, the shaft may be sheared. Then with the motor off, take the cover off and leverage the small chain drive sprocket away from the motor with a screwdriver, and see if the shaft can just be pulled out of its sealed opening. Unfortunately with these bikes, the metals used in drive shafts and motors are not always heat-treated or hardened to the standard they should be, so shearing and premature failure can happen.
4) The gearbox or something in it has blown, unfortunately for the same reason above, quality related.
Its fair to say that these great little bikes are here for a good time, but not for a long time.
more than likely you have broken the item designed to protect the machine. Look for a hole in the hub of the sprocket as it was probably a shear pin try turning over the shaft until you can see the hole to knock out the broken bit. It may also be a key in the key way.
It sounds like the shaft for the sprocket and drive gear has broken or been sheared off. The part number for this assembly is 41C4220A and is available from Sears parts or any good local door opener company. It comes with instructions if you want to do it yourself.
Depends on your mechanical ability. The drive gear is stripped. The part number is 41A2817 and is available at any door opener service company. It comes with instructions.
If the motor is working but the chain does not move you must remove the cover on the motor and check to see that the chain is on the sprocket. If the chain is on the sprocket and the sprocket is not moving but the motor shaft is moving then the sprocket must be retightened onto the motor shaft.
