Two possible issues
one, unplug treadmill remove hood and make sure the main power connector to the motor control box is in properly then turn treadmill back on this has worked for me before
two , you have blown the overload resistor on the motor control board (mcb) to check this unplug treadmill and remove the steel motor control box from under the hood remove the motor control board from inside the box and inspect it for damage and /or electrical burn smell
if you find damage you will need to get it repaired contact glide fitness products in santa ana california 1866 637 4600 for all information including shipping . it cost $200 plus shipping which is a deal since a new one is $1000,i have many repaired by them
a common issue for the overload to blow is friction between the belt and deck board . if you have an auto waxer , the waxer nozzle is usually plugged . the nozzle should be cleaned once a month
contact glide for their non clogging wax to resolve this issue
good luck
