Uniden Customer SupportOn most models you can find an option in the menu for De-register?
In that case you would select that option and select to deregister the
handset.
TRU88 models you go to the
main menu and go to
De-register HS select
yes to deregister the Handset.
DCT5 and DCT6 models: Press
menu on the handset. Go to
System Reset and Press
select. Go to
Deregister HS and press
select. Arrow up to
yes and press
select. Then go back into the
menu. Go to
system reset and press
select. Arrow down to
Replacing the base and press
select. Arrow up to
yes and press
select.
DCT7 models:
Press and hold "end" and "#" until the
system reset menu appears on the display.
Then follow the instructions from above for the DCT5 and DCT6 deregister procedures once your into the menu.
TRU4 and TRU5 models:
Press and hold xfer/del and end until "de-register?" appears. Use the
plus+ button to go up to
yes and press
select.
To register any of the following phones please see you owners manual under either:
•Register handset or
•Register the digital security code.
