the off balance sensor won't adjust the load,, it will notify you if the load is so far out of balance that it needs to be re adjusted . I hope this reply doesn't effect the rating I will receive :)
The list to the right should be resolved. Use a level and level the case left and right, and front to back. The final step is to tilt the machine fully on to the front legs, releasing the self leveling rear legs, and set the machine back down. It should be stable on the 4 feet.
usually this will center the drum and it is more forgiving on balance issues, most of which are common. Be sure to use MORE than enough water for more even loads.
This can be caused by a brake that has failed. Try to spin inner tub with washer off. It should NOT turn. If it turns the brake is bad and is allowing the tub to spin when agitating. This causes clthes to bunch up.
