Re: I ordered a viper 3002, does it have a remote start...
The Viper 3002 is not a remote start system. It is only a security system with keyless entry. In order to remote start your vehicle with the 3002, you will need an add-on unit installed.
the year, make and model of the vehicle; vehicle license number and vehicleidentification number. All ..... One five-button/2-way Supercode Responder LE RemoteControl. ? .... Disarm. Unlock LED blink for one second with 2 Beeps. Remote. Start..... Long-time Viper system users will notice the following differences:.
Viper's elegant new Responder LE transceivers mark a giant leap forward in 21st century vehicle security and remote start, and an evolutionary milestone for the ...
? 2:38
https://www.youtube.com/watch?v=wsSorAf88nw
Jan 13, 2013 - Uploaded by Power2ThePeopleZ
5901 won't start vehicle; gives an error. ... or even try to open the hood. the door remains locked when you start the car with theviper alarm.
? 2:49
https://www.youtube.com/watch?v=cgbQsZuVyt8
Dec 2, 2010 - Uploaded by Paul L
I have a two-way remote from my Viper 5901 system. ... The other car (one in video) has the Viper 5701 system in it. .... and then release 3) press the remote start button 2 times until pairremote is displayed 4)press and old ... I had the same problem that the remote won't pair with the system no matter what.
When u unlock the car count the amount of time the light flashes is a code for what is triggerin it
then Google the number of flashes on disarm viper 3002
Hi Kih8259!
The vehicle might be in "Valet Mode" this does not let the remote start the car.
In order to exit Valet mode do the following: Press and release the F button twice and then press the unlock key. Now, try and start it again to see if it worked.
Hope this solved the problem!
Honestly, you would be taking a risk. You have to remember that if you do, you will always need to keep the car out of gear in order to start the vehicle. You will also need to install an extra relay in order to bypass the clutch switch. Very unsafe, but good luck.
the problem isnt with remote starters, or with viper products. the problem is with under qualified persons attaining products they have no qualifications to operate. TAKE THE CAR TO A DEALER(VIPER ALARMS) and they can fix the problem. remote start was designed for people who want to start their car from afar and could actually comprehend that the multifunction remote was not only a keyfob to lock a door , or start a car, but it is also capable of remotely accessing certain programming features of the viper alarm, and whilst in some goofballs pocket........while he was sucking down goldslager was unintentionally reprogramming the viper alarm, and setting it into various modes of operation. your lucky you didnt accidentally program it into carjack mode. lmfao
A couple things here. It is best to have a "tach wire" and the system needs to be programmed to learn the tach signal in order to know if the car is running or high reving or dead. If it gets no signal of the sort the next option is voltage monitor, it monitors the voltage for an increase to show that the alternator is running. Either way that signal is not gettting to the viper brain or it has not learned that signal. You need an install manual, did you install the alarm?
