My GE XL44 stove preheats and cycles ok but food takes forever to bake in the oven. We even up the specified temp by 25 degrees. Is there an offset adjustment on this oven or any other suggestions? Thanks
First of all, most oven thermometers move very slowly compared to the electronic sensors and controls on the oven. To make sure you are getting an accurate reading, the thermometer should be in the center of the oven, the oven should be preheated, then wait another 20 minutes after the preheat beep. If the temperature is less than 35 degrees higher or lower at this point, it can be adjusted via the controls. Usually on GE ovens you press and hold bake and broil at the same time until SF comes up in the display. Then press bake, then use the arrow keys to raise or lower the temperature setting. If the temperature is more than 35 degrees off, you may have a bad sensor, bad control board, or other problem.
Hello there and welcome to fixya When
the food you're baking is done on top but not on the bottom--or when
baking just takes far too long to finish--the bake element may be burned
out. You
may get fooled into thinking it's working, because the oven is hot
inside. But many electric ovens use the broil element, too, during the
preheat and bake cycles. So the food may be getting heated only by the
broil element, which causes poor baking results. If
the bake element is burned out, replacing it should solve the problem.
To determine if the heating element is burned out, watch the part testing video
at the bottom of this page. Otherwise, you need to further troubleshoot
the oven's electrical system to locate the defective wire or component.
When
the temperature is consistent but too high or too low, it could be one
of several different things. First check to see if the thermostat
sensing bulb has come loose from its holder. It could be lying on the
floor of the oven or resting on the heating element. This would cause
the oven to not heat correctly.If the thermostat bulb is not dislodged, it's likely that the thermostat or sensor is either mis-calibrated or defective. Electronic
ovens with a digital display use a sensor to monitor oven temperature.
To solve temperature problems for these models, you may need to replace
the sensor. On some digital-display models, you can calibrate the
temperature using the key pad. See your operator's manual for details. Ovens
without a digital display often use a mechanical system for controlling
temperature. On many of these units, you can remove the thermostat knob
and adjust the knob itself to more accurately represent the actual
setting of the thermostat. If,
when you remove the knob, there's a screw on the back of it with a
small calibration plate, you can loosen the screw, adjust the plate,
then tighten the screw again. If the knob isn't adjustable, and the oven
temperature is off by more than 30 to 40 degrees, you need to replace
the thermostat to solve the problem.
More than likely, its your oven thermometer thats taking a half hour to read correctly. The oven is probably getting there sooner. If you had a digital thermometer, the read would come quicker. So save your money,nothing wrong with your stove.
When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out.
You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results.
If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component.
http://www.applianceaid.com/nuker.html
click the link
Oven temp sensors sense the temperature is the oven cavity and the temp sensor changes resistance, this change in ohm resistance tells the oven control what temperature the oven cavity at and tells the control to shut off the element or turn it back on. The most common temp sensors used today ( *not all ) are approx 1000-1100 ohm resistance at room temperature ( 70�F ) Some ohm readings and there temperature: Degrees F - Resistance 100 - 1143 ohms 200 - 1350 ohms 300 - 1553 ohms 350 - 1654 ohms 400 - 1753 ohms 500 - 1949 ohms
I just solved this problem with my GE gas range. I waited forever for the oven to warm up. The igniter would glow, light the burner and burn for a minute or so and go out. It would repeat this process till oven reached operating temp, which took forever. Problem is in the igniter. It may be glowing, but it is not letting the gas valve stay open, because it is not hot enough to create resistance in it to keep gas valve open. I had replaced the thermostat thinking it was the problem. The good part about it was I could take it back because my buddy works at supply house. Once the igniter was replaced, the oven fired up and stayed lit till operating temp was reached. It will also hold the oven temp much better. Oh yea, the igniter will stay glowing while the burner is on. Hope this helps.
First let me address the temp ... Buy a meat thermometer and test it against the temp set in the oven. Though that isn't the most accurate, it should prove whether or not it is way way off.
Second.. convection baking takes considerably less time....
Third... elevation plays a key factor on baking but not so much on cooking meat. Baking above 2500ft elevation takes 20% longer and above.
I have just checked the baking guide in the manual and have found that it may not be us after all. (Maybe this is why they telll us to read the whole manual. Well, I never have) According to the cooking time for Baking, the range is very extensive. For example, an angel cake at 350 could take from 28-50 minutes, buscuits at 375-400 could take 8-16 minutes, layer cakes at 350-375 could take 25-40 minutes, pound cakes at 325-350 could take 45-70 minutes and fresh pies at 400-450 could take 35-60 minutes. Basically, the baking directions on the box means absolutely nothing to use Amana oven owners. We have no choice but to cook our food or baked goods until they are cooked, whenever that may be. :) Linda
