It depends on the model that you have. I may have some replacement screens for that device, but I need to know the exact model number. (DIsto LIte5, Classic5, Classic5A, and DIsto A5) . Leica does not sell these parts, you just need to find someone that has an old unit like yours that still has a good screen. Contact me with the model number and I can let you know if I have any.
Greg DeTray
Distagage.com
SOURCE: leica disto classic 5a
The optical lens of a laser rangefinder must always be kept clean for optimal performance.
The most common cause for a reduced range on this devices, is caused by dirty, or defective lens.
If the lens are dirty, on the outer or inner side, or they are opaque or defective, or there is wet inside the lens, than that is the cause for the sensibly reduced range.
SOURCE: leica disto A3 button broke
Mike,
Leica does not sell replacement keypads, if the unit is less than 2 years old they will cover it under warranty. Contact the dealer you bought it from and they can handle the warranty exchange. If it is over two years old, it is out of warranty, but they offer a "repair" option, which will replace your damaged A3 with a new D3 for about $215. If you bought it from a reputable dealer, you shouldn't have any problem.
Hope this helps,
Greg DeTray
www.distagage.com
SOURCE: Disto A3 - problem acquiring readings over 3-4m
A short rectangular "dot" is normal, a 255 error indicates that you are not getting enough reflection back to the optics. This may be due to the surface you are aiming at. Try placing a piece of white paper over the surface, if it does not measure 30 or 40 meters to a sheet of white paper, indoors, and the optics are clean, I'd contact your dealer to initiate a warranty claim. 3 or 4 meters should not be a problem unless the surface is very rough, such as dirt or sand, or very dark color.
If you just bought the unit from a licensed distributor, you should have at least a two year warranty, possibly 3 years.
Greg DeTray
www.distagage.com
