There might be some technical problem.It can be with the card reader slot probably.Try using the memory card on another card reader if it works replace your card reader as it is faulty.Also do check that none of the cables connecting the card reader to the p.c are defaced/damaged.Do make a note that the Port on which you are using the card reader is working properly when you attach some other device to it.If still your card does not work then your card is faulty reaplace it with a new one
