The lightning bolt is the flash indicator. Are your batteries full? Try turning the flash off and fire off a couple of shots....do they work?
ok I took apart my camara and it seems to be the actual button a small clip is broken. It works great manually with housing off but unfortantly you get a slight shock!!!! lol - I have looked on ebay for a broken "for parts only" camera and seem to have found one for under $6. Lets hope I can get it fixed. The one Im buying only has broken screen so I might just switch screens. THANKS FOR YOUR HELP/ADVICE Typrice!!!
• If you are taking pictures in low light (dim light) and the flash is required, the flash will operate
automatically. A lightning bolt appears on the LCD screen and blinks until the flash is ready.
• While holding the camera steady, press the shutter button to take a picture.
Hint: The flash works best when your picture subject is about 4 ft. - 7.5 ft. (1.22 m - 2.23 m)
from the camera.
• When the batteries are getting weak, the flash will not fully charge and the no flash lightning
bolt appears on the LCD screen. It's time for an adult to change the "AA" (LR6) batteries,
Hope this works!!!
Soyleonel
18
