To effectively troubleshoot that you will need to use an electric meter...
The voltage that runs the solenoid valve is 24vac .... check at the power supply (transformer) or furnace for power going to the humidifier... then follow the power through the humidistat and to the valve...
If the power stops... you found your problem...
That is really the only way you can check that out...
heatman101
