20 Most Recent Honeywell HE365 Humidifier Questions & Answers
Hello, if the water continuosly flows thru even with the humidistat turned off then your solenoid valve is bad and must be replaced.
Honeywell HE365... | Answered on Dec 29, 2015
No, it will not stop flowwing if it is the water supply. A solenoid valve opens the flow everytime there is a call for humidity, but it stops at the humidifier when there is no call, so it will leak from that point until it is fixed or tightened.
Honeywell HE365... | Answered on Mar 30, 2014
Check to see if there is 24 volts at the transformer when the blower motor kicks on, if not the transformer will need to be replaced. If you do have 24 volts then work you way from the transformer toward the solenoid and see where the voltage stops, could be the humidistat.
Honeywell HE365... | Answered on Dec 15, 2012
Hello. the buzzing sound you are hearing is coming from the solenoid valve on your humidifier. This could be due to low water flow going into the solenoid or the valve itself is going bad. I would check the saddle valve first and make sure you are getting a good stream of water to the solenoid valve, sometimes sediment gets built up in the saddle valve preventing water to flow. If the water flow looks good then replace solenoid valve.
Honeywell HE365... | Answered on Dec 14, 2012
Hello, if you have a email adress I can send you the maual in a pdf file.
Honeywell HE365... | Answered on Mar 07, 2011
Hello, there should be a thumbscrew on the front of the unit that you turn to open the unit, once you loosen this it should come off, if not try moving the front cover a little it should come off. You do not have to unplug the connector but make sure the power is off to the unit when replacing the filter.
Honeywell HE365... | Answered on Feb 18, 2011
Hello, the first to confirm is if you are receiving 24 volts at the transformer, if you are then check for 24 volts going into the humidistat and out of the humidistat, if voltage is confirmed there then check if your solenoid is recieving 24 volts, if it is and the solenoid is not letting water into the humidifier than your solenoid is bad and must be replaced. If you do not have 24 volts at the transformer then turn off power to the transformer and set your meter to read continuity, you should have resistance if not the transformer is bad and must be replaced. If you have power to the humidifier and not humidifieing properly then you have to set the humidistat according to what the outdoor temp is, the outside temp determines what setting and % of humidity you should have in your home. Here is a what it should be
-20 set to 15%
-10 set to 20%
0 set to 25%
10 set to 30%
20 set to 35%
above 30 set to 40%
Honeywell HE365... | Answered on Jan 25, 2011
The first thing I would do is to check the solenoid valve to see if it is closing fully when then t-stat is not calling for heat.This can easily be done by loosening the compressin nut on the leavig side of the soleniod valve. Do this with the furnace off and the thermostat down far enough to make sure it stays that eay.You should get a few drops out but if is under pressure it will spray.
If it's is not closing you can take valve apart and clean or buy a new solenoid valve. I hope this Helps you. Thank you.
Honeywell HE365... | Answered on Jan 24, 2011
Hello, the most common reason this happens is because the solenoid valve is bad and remains open allowing water to flow continously regardless if the furnace is on or off. I assume you have either a sail switch or current sensing relay energizing the humidifier when the heat is on, if not thats another reason it would run continously.
Hello, yes you can their are many sites who have tablets
here is one http://www.totalvac.com/2HT.html
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Honeywell HE365... | Answered on Jan 05, 2011
The saddle valve that controls the water is only to be used as an "on" or "off" control. It is not recommended as a throttle valve since it can leak if it is not placed in the full open or fully closed setting
Honeywell HE365... | Answered on Jan 01, 2011
Sorry to read about your problem, I hope this helps you out.
try soaking in white vinegar or lime away.
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Honeywell HE365... | Answered on Dec 21, 2010
I have the exact same problem. I can hear the solenoid "click" but when I try and "blow" threw it I cannot. I removed the little screen filter inside where the copper pipe connects, still no luck. Not sure what the flat blade screw is for with the locking nut, other than to adjust the position of the solenoid. I checked for flow of water outside of the valve. Also my contractor hooked this up to the Hot water side of the water heater. Does anyone know if this is correct? I would think you get more corrosion on this side.
Honeywell HE365... | Answered on Dec 13, 2010
Check the hose running to the humidifier after the solenoid, it could be plugged.
Honeywell HE365... | Answered on Dec 11, 2010
To effectively troubleshoot that you will need to use an electric meter...
The voltage that runs the solenoid valve is 24vac .... check at the power supply (transformer) or furnace for power going to the humidifier... then follow the power through the humidistat and to the valve...
If the power stops... you found your problem...
That is really the only way you can check that out...
heatman101
Honeywell HE365... | Answered on Dec 04, 2010
Honeywell HE365 Humidifier Logo
50 questions posted
Top Honeywell Humidifiers Experts
Dennis
Simon Benzekri
Level 1 Expert
jdthefixer
Are you a Honeywell Humidifier Expert? Answer questions, earn points and help others
View Most Popular
  • Honeywell Humidifiers
Most Popular Question
install supply return duct
  • Humidifiers
