Boss Rc 50 Logo
Posted on Dec 04, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Boss RC-50 has stopped working. I used the power chord for my RC 50 in my Boss OC 3 pedal and then tried using the chord in my RC 50 again and it won't work. It won't even work with other power cables. Do you know what's wrong?
Fred Yearian
Level 3:
  • Boss Master 5,603 Answers
  • Posted on Dec 04, 2010
Fred Yearian
Boss Master
Level 3:
Answers
5603
Questions
Helped
2250551
Points
16163
CHeck the voltage out of the adapter. It should be around 9 to 11 volts. If it is not, it is possible that the OC3 has reversed polarity AND a protector that put a short on an incorrect supply. If so, it could have damaged the RC50 adapter. If the RC50 adapter is putting out correct voltage, then I suspect the inout connector on the RC50 may be damaged or not quite seated. Visually inspect the connector first.
Anonymous
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Feb 26, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
789
Points
42 reptn st
london
e147px
tip
RC looper and DR880 syncing.
RC-50 & DR-880 Setup
Rather than using the RC-50 to change patches on the DR-880, I have connected an FS-6 footswitch to both the RC-50 & DR-880. This gives me control of both units, I can select up & down through the patches easily.
Use a dual TRS connector and 2 stereo "y" cables connected to ports 1,2 & 3.4 on both units.
Once connected, you will need to assign the control function for each control port. I assigned Patch Decrease to CLT 1,2 & Patch Increase to CLT 3,4 on both units.
I then connected a MIDI cable from the RC--u control of start/stop & tempo via the RC-50 footswitches.
My RC-50 suddenly won't power on.
Has the unit ever had another ac adapter plugged into it?
Mar 04, 2013 • Boss Rc 50
Can i add more memory to the rc50 loop pedal
You can make a backup on your pc and load back Default settings or restore to default settings. Normally you should have I quote ' with up to 49 minutes of mono recording time (or 24 minutes in stereo), the RC-50 can function as a song recorder as well as a looper'
I have the RC300 which has 3 hrs recording time. But when i reach the limit. I make a backup and load back in a initial default setup which I have downloaded somewhere. But you can also restore to default from the unit itself. Hope this helps
Apr 14, 2017 • Boss Rc 50
The Auto on my Boss RC2 sometimes doesn't seem to pick up a signal and engage. It is plugged into a multi- socket adapter and I do not have the amp turned up too loud as the room is tiny. I thought it was...
Sometimes, with BOSS pedals, the battery must be disconnected before using another power source. I ran into the same problem with my DS-1 distortion. If it's not that, then check the power rating of the power adapter. It should read, for the output, exactly 9V DC. If it doesn't, then you have to get a power adapter that has that same rating. Boss pedals will not use anything other than 9V DC (I know, I've tried).
Hope that helps!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/cameron_463100ffd54b591d
2helpful
2answers
I have the Boss RC-50 Loopstation. It has been great. Perfect operation for about 8 months. Today, when I started to use it, I noticed that I couldn't select "Phrase 1" by tapping the pedal....
Likely the switch contacts for that pedal have failed. You will probably have to get it repaired. Stomping on the pedals is a good way to damage them, but the switches are often marginally designed anyway...
If you can access the switch you could try getting some CRC226 available at Home Depot in the electrical department into the switch, but often the internal parts of switches fail.
Jan 30, 2011 • Boss Rc 50
2helpful
I damaged my boss BE 50 by using the wrong polarity. now it only works on batteries. what can I do.
You are probably fortunate that more damage was not done.
Open the unit and you will likely find a protective diode at the input and either a fuse or that a circuit trace has been blown. Replace whatever is not conducting the power from the power jack to the rest of the circuitry. The diode is probably OK as usually the battery power is across it when the battery is used.
Aug 10, 2010 • Boss Rc 50
2helpful
2answers
Beggining of loop missing on FIRST playback only, on Boss RC-50.
Ok, solved this problem by visiting roland U.S. site as the help offered in this country is useless. The instructions given by email would not have worked even after the update was installed. Luckily, there are instructions that come with the download. If you have same problem as me go to http://www.rolandus.com/products/productdetails.php?ProductId=772&tab=downloads&skip=true
and update the opperating system on the RC-50 to RC-50 System Update Version 1.01.
Then hold loop sync and phrase 2 button (think it was phrase 2) to change it to sound priority mode. Then it will play back correctly what you recorded on the first loop, rather than missing the first beat.
Am v.happy I have found this, as after much searching I can't find any other loopers out there that offer 3 seperate loop tracks and the ability to switch between them effectively. Plus, it's a very convenient size, better than a load of rackmounted stuff to haul around.
However.....
Another problem..
When hitting the reverse switch ( I assigned both external footswitch and the onboard Tempo pedal to reverse) the change is not instanteaneous. There is a second or so delay before it plays in reverse. Not a problem for most, I suppose, but I have a piece that switches rythmicaly between playing forward and reverse which means hitting a pedal in time and reverse/forwards changing immediately. I think they could do with another software update to solve this. Now I have to keep room in my enormous pedal board for the old rc-20, as that does the reverse as it should - when you hit the flippin switch!
Jun 19, 2009 • Boss Rc 50
Top Boss Music Experts
ADMIN Andrew
ADMIN Andrew
 Mikey
Mikey
ADMIN Eric
ADMIN Eric
Are you a Boss Music Expert? Answer questions, earn points and help others
