Thanks so much, i posted and you replied so quickly. I was wondering what type of place i should look for. There's a best buy with a geek squad but i've seen them mis diagnose a couple of friends' pieces of technology and i'm not sure if that's the greatest place. Any suggestions?
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer. If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial. Thanks and regards Please kindly rate this solution Stelios direct fixya link: http://www.fixya.com/users/technical114
The blinking "clean light" is a common problem with some of the Kenmore and Whirlpool models dishwashers. The problem is usually attributed to water supply temperatures being too low when filling. Apparently, there are some issues with the temperature sensing circuits in some dishwashers that causes an error code to be generated if a certain water temperature is not achieved in a specified time interval (this time may differ between models). There is a reset sequence that you can try to clear the fault. Push the NORMAL WASH then HEATED DRY buttons in that sequence two to three times. The unit will enter diagnostics mode, but can be stopped by pressing the CANCEL button. This will clear any existing faults and should return the dishwasher to normal operation. To keep the fault from returning, it is recommended that you run your hot water faucet in the kitchen until it runs hot BEFORE you start the dishwasher.This will heat the water in the supply line for the dishwasher (most dishwashers are fed from the kitchen sink supply line). The theory is that if you fill the dishwasher with hot water from the start of the wash cycle instead of the cool water that is normally in the lines (especially if you have a hot water tank located far away from the kitchen), this should satisfy the requirements of the temperature sensing circuits. If the fault reappears, there should be a tech sheet located inside the lower panel under the door that explains what the fault is. The flashing light will be a series of flashes, followed by a pause. If you indeed have a component problem, it will depend on the number of flashing lights in the sequence. Refer to the tech sheet to determine WHAT component is affected and how to troubleshoot.
Unfortunately, the internet is indeed unable to be used in Taiwan due to different country internet policies. You will need to go back to Bangkok, or a similar internet system-ed country, for it to work. My apologies for the inconvenience. Thank you for using FixYa! =) Please rate. Kindest Regards.
Either manually select your card with Option 1 or automatically with Option 2. Post a reply if you have any problems with the download or please rate this solution if you found it helpful.
Thank you!
Edward
There are many laptops on the market that could suite your need. What size screen would you like? What operating system do you perfer? (XP Pro,Home, Vista...) How much storage would you like? (100GB, 200GB..) My company sells many brands of notebooks and may be able to help you in your qwest. I would be more than happy to give you a free quote. Please email to [email protected]. Thanks
Respected Sir, This is Praveen from Chickaballapur(karnataka) I am interested in Tata Nano Dealership. I have my own land on around 15000 sp ft. Please reply me with the procedure for application on my mail. It is [email protected] Waiting for favorable reply. Thanking You
