Cooktops Logo
Posted on Jun 26, 2008
GE Spectra electric burner always on high
I've got a GE Spectra EER3000 electric glass stove top. Even though I have tried a number of lower settings, the front right larger burner effectively goes to high. I've scorched a couple of pans and burned food. I assume there's some kind of heating element or control that's gone bad . . . The other three burners are operating normally.
  • Anonymous Sep 23, 2008
    I have a Whirlpool Electric smoothtop cooktop model number GJC3034RB. It's only 2years old and the front left burner stays on high no matter what you put the burner control switch to.
  • dougro1 Mar 04, 2009
    My problem is the "outer" burner on the right won't regulate at the same temp as the "middle" burner. GE Spectra.
Anonymous
Level 1:
  • Contributor 59 Answers
  • Posted on Jun 26, 2008
Anonymous
Contributor
Level 1:
Answers
59
Questions
0
Helped
42709
Points
84
Sounds to me like the RF switch is bad.
Eddie Rentas
Tupper Lake NY
How do I plug back in the GE stove top burners after unplugging them?
The two leads from the burner fit into a socket in the stove top. It's a bit tricky to get it in just right. If the three metal "legs" on the burner fit snugly into the three slots on the stovetop you did it right.
1helpful
I have a glass 4 gas burner stove top and cracked the glass, can I replace it? Its a GE Profile with a stainless steel front lip
Yes the glass is replaceable, you will have to order a new one, and you could do so through an appliance parts store. They can even put it in for you.
I have ge jgp337 . My gas stove started ingniting without turning the burners on and all flame started coming out from all 4 burners. i switched off the electric switch now even after 2...
I've seen this problem before. It happens when spillage get's into the ignitor switches. The switches are mounted on top of the gas turn-on valves. You have to replace all the ignitor switches because they are connected into wire harness. Rich
6helpful
2answers
Burner only cooks on high heat.
You need the switch for that burner. The contacts inside are stuck together. You will need to pull the unit and separate the glass from the lower body to access it. To get the right switch you need full model and serial number located on a plate at the bottom of the unit.
Your ability to perform this is dependent on how mechanical you are. The Whole unit must be removed from the counter opening and the base unscrewed from the glass, remove knobs before disassembling. For someone mechanical this is not difficult. De-energize whole unit first.
Once the two pieces are separated the remainder is mechanically easier. Disassemble the box on right containing the switches and replace the correct one. Reverse the process for reassembly. Good Luck
Broke glass on electric genn-air
Please do not use the stove if the element is viable because of broken glass, this could become a danger to yourself.
Look at the cost of a new stove, you should be able to get one for
around 400.00. One of my customers had a glass top with 4 burners,
they had the same thing happen, the cost to replace the top was
1,200.00. So I would assume that you can get a new stove with 4
burners less then it would cost to replace the part on a stove you don't like. Maybe there is a LOWES around you to look at stoves,
they seem to be everywhere,like death and taxes.
As for putting a 4 burner top on a stove that has 2 with grill, I don't think it can be done without the extra cost of adding the parts to run the other 2 burners, so like I said in the long run,it just might be cheaper to but a new stove. It should not be a big deal to remove the exhaust from the grill part of the stove.
I looked at the model# you put down,and it does not have a grill,
from what I see, there are 4 burners and a downdraft vent in between the 4 burners, there are 6 models with this part # and none have a grill,only the downdraft vent.
If the model# is right, the cost would be around 300.00 for the glass, and then the cost of having it replaced. So I would say over
400.00, In which case for the same amount you could have a new one, but you must weigh the difference for yourself and see what you think is the best way to go.
If you have any more questions,please post back and everyone is more than willing to help you. I hope I have helped a little.
My electric stove top burner only works on high
This is for the glass top units. well i'm not sure if your problem is with your large or small single burner or the large expandable burner. If it's the large or small single burner replace the burner and if it the expandable also replace the burner. If you have a coil burner replace the infinite switch. Good luck hope this helps you.
Only high setting works on burner
Sounds like the Switch or the element are bad, try trouble shooting them. It's a stove top??
Eddie Rentas
Tupper LAke NY
1helpful
2answers
Ge profile electric counter top stove
I did not receive instructions with my G E Profile cook top Model No. 80030750434). There is a build up on the elements which I am having problems removing. Should the top be scraped while the stove is hot or cold? What is the best cleaning product to use?
Frigidaire glass cooktop
first try putting pans on top and see what they do you should not operate these type of eyes with nothing on them as you will burn out the sensors in the eyes if nothing is there to reflect the heat back to them if it does the same thing with pans on them then you will have to replace the elements
Top Cooktops Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
Are you a Cooktop Expert? Answer questions, earn points and help others
