I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
bosch dishwasher lower spray arm works intermittently. arm no clogged
I have a similar problem - after doing all the obvious things I think there is a problem with a feature called FLOW-CONTROL which can direct water to each spray arm individually - not sure how to fix it though!
Same problem lower arm is not moving! Upper arm moves dishes are not coming out as clean as they should. Does anyone have any solutuons?
