Patton Electric Patton PUH680-U Electric Utility Heater 1500-Watt Logo
Posted on Nov 20, 2010
I have a Patton Pu680 and the thermostat switch is not working. It was manufactured by Tower Norstat but their website will only sell to original manufacturers. Any ideas?
2answers
I have a Patton U2-1287 fan. The knob for the on/off-speed control switch is broken; I need to buy another knob.
To purchase a replacement knob for your Patton U2-1287 fan, you can try the following options:
  1. Manufacturer's website: Visit the official website of the manufacturer, Patton Products Company, and look for a "Replacement Parts" or "Accessories" section. They may offer replacement knobs or have a customer support contact you can reach out to for assistance.
  2. Online retailers: Check popular online retailers such as Amazon, eBay, or Walmart. Search for "Patton U2-1287 fan knob" or similar keywords to find compatible replacement knobs. Be sure to read the product descriptions and reviews to ensure it is the correct fit for your specific model.
  3. Local appliance repair shops: Visit local appliance repair shops or stores that specialize in HVAC or fan parts. They may carry replacement knobs or be able to order one for you.
  4. Contact customer support: Reach out to the manufacturer's customer support directly via phone or email. Explain the issue and provide them with the model number and any other relevant details. They may be able to assist you in finding a replacement knob or direct you to an authorized dealer.
When contacting suppliers or searching online, it's helpful to have the model number of your fan (Patton U2-1287) and any additional information about the knob size or design. This will ensure you find a compatible replacement that fits properly.
Alternatively, if you cannot find an exact replacement knob, you could consider using a universal fan knob that is compatible with your fan's control switch. Universal knobs are designed to fit a range of fan models and may offer a suitable solution.
Have a patton space heater. Light is on when plugged in but will not start. Can you tell me how to fix?
If the light on your Patton space heater is on, but the heater will not start, there are a few things you can try to fix the issue:
  1. Check the power source: Make sure the heater is plugged into a working outlet and that the circuit breaker or fuse is not tripped.
  2. Check the thermostat: Make sure the thermostat is set to a temperature higher than the current room temperature. If the thermostat is set too low, the heater will not turn on.
  3. Check the safety features: Some space heaters have safety features, such as a tip-over switch or overheating protection, that will shut off the heater if it is not positioned properly or if it gets too hot. Check to make sure the heater is positioned correctly and not too close to anything that could cause it to overheat.
  4. Clean the heater: Over time, dust and debris can accumulate in the heater, which can cause it to malfunction. Unplug the heater and clean it thoroughly, making sure to remove any debris from the heating element.
If none of these steps resolve the issue, there may be a problem with the heater's internal components. In that case, it is best to contact the manufacturer or a qualified repair technician for further assistance.
Can I buy a heating element for this heater?
On google
Patton replace heating element Heaters Questions ... - Fixya
www.fixya.com > Forum > Tags > replace heating element > Heaters
Patton heaters replace heating element related questions and answers. Ask yourPatton ... I can't seem to find a phone number for the manufacturer to call for parts. Any help? ... Question about PQH307UM Electric Utility Heater. 1 Answer ...
Patton PQH307UM Electric Utility Heater Quartz elements ...
www.fixya.com > ... > Patton > Patton PQH307UM Electric Utility Heater
Patton PQH307UM Electric Utility Heater, quartz elements replacement related ...Element. Where can I find replacement quartz tube heating. Element Infrared ...
Patton PQH307UM Electric Utility Heater Element ... - Fixya
Patton PQH307UM Electric Utility Heater, element related issues. Get free help, solutions & advice from top Patton experts. ... The heating element is above the thermostat, and all you will see is a round disc with two wires attaching to. Ad.
Patton PUH680-U Utility Heater Replacement fan motor ...
Any idea where I can get replacement metal fan blades for a Patton floor fan?
I'm not all up on Patton Model#s, but this is an older unit, correct? You may try contacting Patton (Owned by Holmes now so you may have to go through them)
If they cannot help you, try www.dtvintagefans.org There's collectors there that may have parts fans that they may be willing to sell a blade.
Alternatively, you may try Grainger, as they sell an assortment of blades. You will need to match a blade to your motor though, which should be fairly easy as the Patton fans use a common McMillan motor which most attic fans also use.
1helpful
Need off-low-high switch for Marvin 2060 heater
As you probably know by know Marvin is no longer in business. The original supplier of the electrical switches was tower mfg. They will not sell to distributers or supplies due to chance of legal matters, they will only sell to oem's. We have looked extensively and have found one supplier at present, if you find on please let us know. The switches we have purchased are 120VAC 13A and have exact mounting, one tab one screw with press in wire connectors. The only difference is this switches' stem is 5mm shorter. This means the bottom outside of the original control knob must be shaved 1/4" this will make for a perfect fit and will make this knob the same thickness as thermostat knob. This switch sells for $6.95 plus postage and comes with directions for modifications.
1helpful
2answers
Power switch replacement
Well unfortunately you cant get one to buy for any case or tower, what you will need to do is get your self a new case(tower) or simply find an old case and take one out from it..
Top Patton Electric Heating & Cooling Experts
Paul Carew
john h
Are you a Patton Electric Heating and Cooling Expert? Answer questions, earn points and help others
