The DVD+R is the older version that was used, all newer ones use the DVD-R now, your problem is the disc is not recognized in the other players because of the different format.
I havDUEL VIEW DSTV and it went on the blink, I kinda fixed TV1 but on the second TV which is LG after I AUTOMATICALLY RESET IT shows only 4 channels sabc 1 2 3 and etv, so now i cant see dstv and i cant find a channel for it, how do i get it back as it was working fine on tv 2?
You can download the complete instruction manual in PDF format by clicking this link.
On the page which opens, click on the "Download" button to download and save the manual.
You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa.
Unfortunately, your recorder is picking up a signal in the broadcast that copy-protects the show. The recorder is programmed to forbid copying of protected material. Depending on the source of the copy-protection, you may be able to block out the copy protection signal with a hardware filter. One example of these would be the Sima CT-2 that is placed between the S-out of the receiver and the S-in of the recorder.
I hope this helps.
Cindy Wells (One common sources with this issue: a DVR that passes on the copy protection to an attached DVD recorder. Particularly some of the new Satellite/Cable receivers with built-in DVRs. The non-DVR models of the products usually filter out the copy-protection.)
Well LG makes this unless you can find a firmware up then you must order some DvD-RW with CPRM this allows you to copy your shows once then recording over them.I got this from LG.It's a common firmware problem that started when digital signals got sent with copy right protections.
I experience the same problem and need urgent help
