SOURCE: Flash makes my pictures too bright/too dark
u might want to try and put a coffee filter over your flash when you take pictures to make the flash less bright. it sounds really silly but it actually works.
SOURCE: Can I use a memory card SD 2Gb in a camera Samsung Digimax S500 ?
Yes, you can use a 2 GB SD card in your camera.
SOURCE: Disk for computer (Digimax s500)
You can download the driver and manual here from Samsung.
http://www.samsungcamera.com/customer/download/cus_down_main.asp?key=s500
THe SD card inside has a lever to its left Side .... Move it upwards ..... That is the lock on the Memory Card ...
SOURCE: how do you change shutter speeds
Select Manual mode by turning the mode dial to M. Press the +/- button, then up/down to change the aperture or right/left to change the shutter speed.
This is on page 14 of my copy of the manual.
